Heads Up display went out
Old Sep 5, 2011 | 12:28 AM
06GrandPrixGXP's Avatar
Default Heads Up display went out
any suggestions i checked the fuse it was good.. it went out when i got it back from the body shop. the body shop just fixed a dent in my hood and painted the hood?Huh?
Old Sep 5, 2011 | 11:49 AM
mike690003's Avatar
Every time i've heard of that issue, it turns out to be the clock spring on the steering wheel.
Old Sep 5, 2011 | 12:27 PM
how do you fix this problem?
Old Sep 5, 2011 | 06:00 PM
Andrew91PGT's Avatar
It's not the clock spring on the steering wheel....that is for the airbag. The spring you are refering to is located in the Hud unit. It holds the reflector mirror at an angle up at the windshield. the spring is held the the base of the Hud assembly via a small plastic clip. Eventually it breaks usually from a bad pothole or bump.... Remove the Hud assy and take it apart.
It u want to know for sure if its the spring, slouch way down and look up above where the steering wheel sits the Hud should still display but way out of position.... Let me know if u need help.
Old Sep 9, 2011 | 12:44 PM
BLKGXP's Avatar
NICE! mine just went out and it was the spring- Thanks for the good info!! Did you take the HUD out from the top of the dash/ is it an easy fix??
Possible Easy & Cheap fix on the GXP... It must be friday
Old Sep 9, 2011 | 09:01 PM
Hawkins04's Avatar
I'm going to try and fix my hud tomorrow does anyone have some pictures of where the spring goes as the write I found has a super blurry picture of it
Old Sep 10, 2011 | 02:39 PM
Hawkins04's Avatar
I fixed the hud when I took it apart the spring was rolling around under the mirror. It was not very hard to do at all but I would say if you do it find someone with small hands.
Old Sep 10, 2011 | 06:36 PM
ryanisl33t's Avatar
Here's a great writeup I used when I fixed mine. Pretty straight forward.
http://www.atthetipwebs.com/technolo...ctions/hud.htm
Old Sep 10, 2011 | 10:13 PM
Hawkins04's Avatar
same one I used too I thought it was going to be harder than what it was. Hardest part was getting my big hands in the tight spot under that top plastic piece to unplug the wires
