Serpentine belt tool?
Old Oct 24, 2011 | 06:55 PM
vroom_vroom's Avatar
Default Serpentine belt tool?
Where do I find the serpentine belt tool for the ls 4? I can't get my alternator bracket off to cut it Down without it? After Much anger I got pissed off and cut the belt trying to get it back on after a failed attempt to get it back on, can you take off the back valve cover with out removing the bracket btw?
Old Oct 24, 2011 | 09:58 PM
MonteSS8707's Avatar
You can take the back valve cover off without removing the alternator. You can change valve springs, rockers and pushrods in the rear without removing the alternator. A tool company called KD tools makes the special serpentine belt tool. I forgot the part number, but it makes things easier. But you cant see where it goes into the tensioner. So its still a pain.
Old Oct 24, 2011 | 10:43 PM
neilownz's Avatar
Some people have done it without the tool. Search...
Old Oct 25, 2011 | 01:44 AM
Yea Im not one of them
Old Oct 25, 2011 | 10:15 AM
leclair87_06monteSS's Avatar
A friend and I did the belt without the tool.
One of us went under the car with a pry bar, to depress tension from that lower spring tensioner, while the other stayed at the top with belt in hand. With the lower depressed, and me stretching the belt that little extra bit it went on just fine.
Old Oct 25, 2011 | 12:29 PM
DavidGXP's Avatar
I just use a 1" wrench that is about 24" long. I spray the wrench down with WD40 and and lift the belt off of the PS pump pulley with a twisting motion. I install the belt the same way. Takes about 2 mins max.
I'll post a vid later this week.
Old Oct 25, 2011 | 01:10 PM
ghetto joe's Avatar
i changed one on an impala just had a bar pushing the tensioner against the weld strip i think, it worked
Old Oct 25, 2011 | 04:20 PM
Mels SS's Avatar
I purchased the tool through the dealer
Old Oct 25, 2011 | 05:50 PM
Andrew91PGT's Avatar
I got the belt on and off by kneeling on top of the intake and pulling as hard as I could up and slid it off. Same to get it back on. Helps to drink couple beers and get mad at it first! Lol
Old Oct 26, 2011 | 02:45 AM
Yea 3 guys could not get it back on and my buddy did the same thing on his Gxp and didnt have that. Much of a problem. Still need to get the tool so I can get the tensioner out of the way so I can get the bottom bolt out of the bracket.
Old Oct 26, 2011 | 10:49 AM
DavidGXP's Avatar
And.... why are you removing the bracket again?
You don't need the tool. Slip the belt on, and use a flat edge-less wrench/bar with lube, and lift the belt (tool under the belt, in-between the PS pulley and idler pulley) up and over the PS pulley. Try to create a sliding motion.
Old Oct 26, 2011 | 03:52 PM
Ls6 intake& rail
Old Oct 26, 2011 | 05:07 PM
Mels SS's Avatar
And scare up your pulleys
Old Oct 26, 2011 | 05:25 PM
wow i am a flippin idiot just had the realization that if i took the bottom bolt off before i took the belt off i could of got the bracket out ( tensioner would of been of been down farther out of the path of the bolt) and i could of been running around a lot happier instead of pissed off at the car
Old Oct 26, 2011 | 08:30 PM
DavidGXP's Avatar
The first time I removed my alt bracket I broke the tensioner. 165.00 lesson!
My pulley's look new. Use lube and have no worries!
Old Oct 27, 2011 | 07:39 PM
Mels SS's Avatar
I have the tool and no worries!!
Old Oct 27, 2011 | 07:46 PM
xxtheshockerxx's Avatar
how much is the tool?
Old Oct 28, 2011 | 09:16 AM
Mels SS's Avatar
When I purchased the tool the dealership didn't even have it. It was $105 at that time it should be less by now
Old Oct 28, 2011 | 10:34 AM
neilownz's Avatar
Now it's more. I got one off ebay back in the day for like $50.
