Better mpg?
BEG, BORROW< STEAL for a way to have it disabled. Then do an oil change with oil for a desiel engine for 500-1000 miles, and then clean all of your induction system and a fresh regular oil/filter change... then be a happy camper!
lets say you have intake/exhast, while cruising on the highway your engine will not have to work as hard to suck in the air and blow it out. so you will have a better performing engine and you will increase your mpg.... but as soon as you get on the throttle pretty hard your engine will be able to move more air in and out and this means it will need more fuel to keep up with this increase air flow... which results in a loss of mpg....
so its a balance. i had a full bolt on car for a long time and the mpg actually dropped a little because of "spirited" driving... and the best thing i did do for mpg was switch to 0w 30 amsoil... gave me around 3mpg if you can believe that
