Custom Painted Hoodliner
Old Jan 13, 2012 | 09:15 PM
MY06GRANDPRIXGXP's Avatar
Default Custom Painted Hoodliner
Ok so a few people have asked me now how I got the GXP emblem painted on my hoodliner so I though that I would do a little write up. I can't take all the credit on this one though. I originally saw this thread at Grand Prixs of North America: http://www.gpona.com/forums/do-it-yo...liner-t40.html I just used the GXP Logo which is a bit more complicated but doable. Total time frame for this was less than a day including dry time for the paint.
I followed the thread's instructions and removed the hood liner by taking out the push pins. Once it was out I brushed it off and did not wash it. I had a can of some generic high temp black paint. I think I used "woodstove black." After a few light coats I was happy with the even black color of the hoodliner.
Next was the hard part; finding a good stencil. I attached the file below that I used. I was able to print this out on six 8.5x11 sheets of paper and then tape them together. (I used a photoshop like program to be able to blow the logo up and divide it into 6 pages) I used a sharp hobby knife and scissors to cut out the black parts in the attached file. Take your time.
Next, I taped the stencil to the hood liner using double sided tape and blue painters tape. I was extra careful on the diamonds segments. Then I masked the rest of the hood liner with newspaper so I would not get overspray on it.
I used VHT brand red caliper paint because I had some of that laying around too. It took many light mist coats to get the color you see below.
I did this back in June before Carlisle GM nationals and I took these pics tonight so it seems to be holding up well.
Some advice if I were to do this again. I used regular printer paper for my stencil. As I painted more coats of the Red the paper began to curl up on the edges (it takes a lot of coats to get the color I got). I would use a heavier paper like cardstock or maybe try and print it on label paper.
Let me know if anyone has any questions or wants more pics.
Old Jan 13, 2012 | 09:46 PM
GXP25's Avatar
Do it over again with the proper "GXP" logo:
Btw, the image above needs to be "fixed" as well.
Old Jan 13, 2012 | 10:23 PM
Yeah I should have mentioned I reversed the grid part because I liked the look of the grid painted red.
Old Jan 13, 2012 | 11:04 PM
rm08gxp's Avatar
Awesome, Thank you!
Old Jan 14, 2012 | 07:46 AM
Mels SS's Avatar
Awesome Very nice job!!
Old Jan 14, 2012 | 08:08 AM
Hawkins04's Avatar
Nice thanks I may have to try this sometime. Can you get the hoodliner at the dealer cause mine is ripped real bad?
Old Jan 14, 2012 | 09:23 AM
I would think you could get one at the dealer but it would probably cost ya but maybe not. I will say that the fabric on the edges of mine was starting to pull away in a few spots so I used a little superglue to hold it back down before I painted it.
Old Jan 14, 2012 | 03:57 PM
kweevuss's Avatar
how did you break up the picture so it would be big enough to print on 6 sheets of paper?
Old Jan 14, 2012 | 07:35 PM
GXP25's Avatar
Nothing's reversed. The image is just wrong.
I've already been through this with others on another forum...
Old Jan 15, 2012 | 08:43 AM
texasGXP08's Avatar
GXP25's image is the correct one. I made it from a photo of our door emblem. Hence, it is not %100, but close enough for small uses.
Old Jan 15, 2012 | 02:49 PM
bignosecaveman's Avatar
You can also use a program called rasterbator to make an image as large as you like.
http://the-rasterbator.en.softonic.com/
Old Jan 15, 2012 | 06:32 PM
texasGXP08's Avatar
I used illustrator to make a vector.
Old Jan 15, 2012 | 07:05 PM
kweevuss's Avatar
Im not a pro in illustrator but after you make a vector im guessing you can change the size. And I am going to use Gxp25's picture. When i go to paint it, should all the squares be filled?
Old Jan 19, 2012 | 09:22 PM
ghetto joe's Avatar
ok i wanna see someones that used the correct way to compare
Old Jan 19, 2012 | 10:42 PM
GXP25's Avatar
That image I posted actually needs some slight work. A good alternative for the logo is the door sill plate since it's flat, versus the door badges.
There is no need to hesitate on which square needs to be filled. As the image shows, it's black on white. Anything that is colored in black in the image needs to be painted.
So, if you're painting the hoodliner, I'd paint it white since the hoodliner is relatively black.
At the end of the day, it's all up to you.
Old Jan 20, 2012 | 12:07 AM
Dougs07GXP's Avatar
i did a little work so that i didnt have to wast so much ink
Old Jan 20, 2012 | 12:09 AM
Dougs07GXP's Avatar
image didnt show
Old Jan 20, 2012 | 12:14 AM
Dougs07GXP's Avatar
