Lowering time
Old Jan 18, 2012 | 10:57 PM
RPM07LS's Avatar
Default Lowering time
Well ive been stuck between some things. I have about $200 to spend on my car. First thought was getting the widows tinted, but I've made it this far without. Then I saw the lowering springs on Canuck motorsports that have a nice drop for 200. Question with that, do I have to get the camber kit or can I do without it? I know I'll have to have an alignment done after a couple weeks. And I Hav brand new tires on the car, about $1000 worth so I don't wanna chew them up.
Does anyone have pics of the 2.5,2.0 drop on their car? I would love to see how it looks. Any other suggestions will be considered also.
Thanks fellas.
Old Jan 18, 2012 | 11:06 PM
robcas47's Avatar
ooops
Old Jan 19, 2012 | 07:43 AM
Hawkins04's Avatar
You can only get a 2.5/1.5 drop for your car and you will need the camber bolts. You will need an alignment right after so no waiting. I just did this same drop a few weeks ago I'll post pictures tonight
Old Jan 19, 2012 | 07:46 AM
rm08gxp's Avatar
Can you assist wih part numbers for the camber bolts? cant find them at autozone or advance?
Old Jan 19, 2012 | 08:18 AM
Hawkins04's Avatar
Part no. k5330 at advance auto that is for one you will need 4 or if you want to make sure the alignment is perfect you can buy 8. That part number should be good at any parts store. I would recommend to get 8 just to be on the safe side when getting an alignment
Old Jan 19, 2012 | 08:38 AM
94ss06gxp's Avatar
Originally Posted by robcas47
Before you lower you should consider an adjustable panhard bar (PHB) and lower control arms(LCA's). The LCA's don't really need to be adjustable but the PHB does so that you can properly center your rearend after lowering your car, especially as low as 2-2.5". These two are very good upgrades regardless of lowering your car or not since they stiffen up your suspension and help with traction on launch and in the corners. Also even though you won't need adjustable LCA's (but still recommended) you will want to get the relocation brackets for them.
wrong section
Old Jan 19, 2012 | 09:11 AM
RPM07LS's Avatar
Sounds like a little more work I want to do in my cold garage. Lol I think I'm gonna set the money back and after winter do all that. Definately appreciate the info though.
On aside note I met a guy yesterday that had a black 08 gxp with 25,000 miles on it and he bought it brand new. I was quite amazed. Was telling me about how his rear stock suspension sagged so bad it chewed up both back tires. I have 88k on mine now and I have yet to have any problems. Beside my RR strut going out. Tranny is still very strong and no signs of slipping, yet.
Old Jan 27, 2012 | 09:39 PM
RPM07LS's Avatar
You get those pics hawkins?
Old Jan 27, 2012 | 09:51 PM
20SS06's Avatar
Check my sig
Old Jan 27, 2012 | 10:39 PM
GXP25's Avatar
You only need four camber bolts.
ACDELCO Part # 45K18036. Get them from RockAuto at ~$13 each.
Old Jan 29, 2012 | 10:39 AM
Dom87SS's Avatar
I have the SSC springs and I used 4 camber bolts. It barely I mean by a hair got me in the green on the alignment rack. If I was going back in, I would have put 8 camber bolts in to get the alignment better. As you can see in the pics the springs were far from sagging, and the lowering springs didn't get me much of a drop. Average about 1" all around, wish it was another inch lower.
Before
After
Old Jan 29, 2012 | 01:54 PM
crazyjoe's Avatar
I used the 1.7" drop front and rear and didnt use any camber bolts whatsoever:
Old Jan 29, 2012 | 05:37 PM
Hawkins04's Avatar
sorry for the delay been busy but here are some pictures of the car before the alignment. (first 4)
