best way to unclog the sunroof drain holes?
![Unhappy](https://ls1tech.com/forums/images/icons/icon9.gif)
Well I got a huge surprise the other morning dropping the car off at the dealer.
There was a wet roof...I was like WTF..but figured it had to be clogged drain holes in the sunroof.
SO question is the best way to unclog them and where else should I look to get them unclogged?
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
Sunroof Drain Inspection and Cleaning
Drain Hose Routing
A drain trough encircles the sunroof window panel and water is drained off by the drain hoses located at each corner of the housing. A drain channel spans across the sunroof module at the rear of the window panel and directs water into the trough.
Check to ensure the front drain hoses are routed down the windshield pillars and out the center of the pillar between the door hinges. Make sure the hoses are not kinked. Replace any torn or cracked hose. Refer to Sunroof Housing Front Drain Hose Replacement .
Check to ensure the rear drain hoses are routed through the rear pillars and out of the rocker panel. Make sure the rear hoses are properly routed in the metal roof slot and taped in place. Replace any torn or cracked hose. Refer to Sunroof Housing Rear Drain Hose Replacement .
Plugged Drain Hose
If a waterleak has occurred check for a plugged drain hose at each corner of drainage system.
Open the sunroof window.
To test for blockage, pour a small container of water into the module housing drain trough. Check each corner to confirm the drain hose is draining water.
Caution: Wear safety glasses in order to avoid eye damage.
Use compressed air, 241 kpi (35 psi) or less to blow out any drain hose that is plugged.
Test the system again.
If the hose remains plugged, check to see it is properly routed and does not have a kink. Refer to Drain Hose Routing.
Remove any hoses that remain plugged.
• For front hoses, Refer to Sunroof Housing Front Drain Hose Replacement
• For rear hoses, Refer to Sunroof Housing Rear Drain Hose Replacement
Remove the blockage using the following steps.
7.1. Push mechanics wire through the hose to remove the obstruction.
7.2. Use compressed air in order to blow out any remaining material.
7.3. Reinstall the hose. Refer to Drain Hose Routing.
Disconnected Drain Hose
Inspect the drainage system for disconnected drain hoses. Complete the following steps in order to obtain partial access to drain hoses and check for a disconnected hose.
Open the sunroof window panel.
Lower the headliner as needed. Refer to Headlining Trim Panel Replacement in Interior Trim.
Connect any disconnected hoses.
Ensure that the rear drain hoses are properly routed in the metal roof slot and taped in place.
Drain Hose Routing
Plugged Drain Hose
Hmmm... 6 years ago, I used 0.08" weed trimming line with a rounded off end to poke the offending matter from the drain hoses (from the top side). My car was delivered with this condition.
