How to hide t1000 trinity wire
Old Feb 27, 2013 | 01:10 AM
SatanBob's Avatar
Default How to hide t1000 trinity wire
How'd ya'll hide the ob2 wire for it in your cars im wanting to make it look cleaner and wanting to get a pillar gauge to mount it because its too cold right now for the suction mount and everytime i hit a bump which is every foot it falls and dings my hand or my head just wondering what everyone else has done
Old Feb 28, 2013 | 10:25 PM
GXP866's Avatar
I was having the same problem. It's too cold for the suction cup to stay on the windshield. First, to run the wire I undid the little plugs holding up the plastic covering next to the obd2 port. Then, I removed the little panel between the door and the dash. What I'm referring to is the covering that looks like the fuse panel covering just on the other side of the car. Last, instead of using the sanction cup against the Window, I just use it as a stand and push the trinity against the windshield so it doesn't slide around. Just hide the extra wire in the open space where the panel covering is. This way, it's looks clean sitting on the dash instead of the Window and it won't fall off either. Just gotta be careful about it sliding around a little bit but this should work until you get the gauge pillar. I hope this was helpful!
Old Mar 1, 2013 | 06:07 AM
SatanBob's Avatar
thanks bro and it is i got super pissed when it hit my head lol
Old Mar 1, 2013 | 09:30 AM
08GXPGXP's Avatar
What I did was similar.. I have my trinity to the left of the HUD. In the far left of the windshield.. The wire is ran along the bottom of the dash up the left side like explained earlier, then all the extra wire I have kinda curled up behind the trinity..
Under the dash I took some Velcro strips and put them up in there. Then wrapped the wire with the other Velcro side..
One thing you want to watch it over by the ebrake.. Mine had got caught in there before I secured it and wouldn't let me ebrake lock in place. Just make sure it don't get between there..
My problem was I had it down and engaged and had accidentally got the wire in the way
