My own poly trans mount done updated** 3/7/13
Found a deal on some poly in the 95A range figured why not, im not forking out 90 for one so similar in dimensions to the stock one. so long story short i cut drilled and did my own version which is about 30%longer and wider to give the trans side more stability plus its sits slightly higher so no more sag on the trans side, using my angle finder its damn near 0.0 degrees before it was almost 1.5 which wont kill anything but it will cause some binding when trying to launch etc... so heres the pics and im considering making a run to make solid poly front mounts but more able to control the motor from twising upwards. ill start a thread when that comes. anyways here is my obese trans mount. If you have any question or considering making your own PM me or ask here thanks for looking
as for installation very simple if you have two jacks which i recomend and a jackstand youll also want to disconnect the dogbone up top. when you jack up the transmision via the jack also place a jack under the ball joint and jack up the control army so your CV axle boot dosent seperate or cause damage the joints themselves. all bolts involved are 15mm
![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20130228_040439_zps433ed78d.jpg)
![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20130228_111331_zps5b4df518.jpg)
old![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20130228_115046_zpsb7c2a2ad.jpg)
NEW
old
NEW
![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20130228_155242_zps6b58301b.jpg)
Nice job. I enjoy reading your posts, so keep it up!
For the not so mechanically inclined, here you go!
http://shop.zzperformance.com/store/...ans-Mount.aspx
http://fieroaddiction.com/LS4/index.html
I will probably put 10-12K miles on my car annually and use it for DD days when it doesn't rain or snow.
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
GD I love this car!
I am still trying to figure out what to do, and wondering if it's worth dropping 700 into. The TPiS modified intake, coupler, and tuning adds up. I already have the TB, and 85mm MAF with pigtails. I am just afraid of only gaining a few HP. Besides, anything below 50mph smokes the tires off, or cause's the anti-score to kick in. Power is useless, unless I gently roll into it. At 60 mph grabbing 2nd cause the car to pull all over the road which is fun, but scary. The retarded part is that I am only around 380 whp, and other LS powered cars, with similar mods, are pushing 450 plus (with bigger engines though
GD I love this car!
GD I love this car!
GD I love this car!
GD I love this car!
UPDATE***
I decided to go for running bolts all the way through i was prepared to ream the upper cast piece a couple mm but turned out i didnt have to the bolts lined up perfectly so i drilled out the old holes and installed a metal sleeve for the bolt to go through and put it all together again. Im a little worried that the car dosent vibrate or anything its dead smooth with the mount. which seems opposite the expectation for 95A poly. but anyway here are some more pics of my work
![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20130305_171732_zpse11fedc6.jpg)
![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20130305_171606_zpsf848a848.jpg)
![](http://i173.photobucket.com/albums/w63/91parkave/IMG_20130307_124744_zps96896d14.jpg)
