question about service traction/brake assist message
Ive posted about this issue before but im going to be more specific this time...it seems ever since I installed and aftermarket intake, these messages appear when driving and it cuts engine power as if I hit the brakes quick..question is...could it be because the filter of my intake is right above my exposed ecm tray? Bc the intake I have has no heat shield around it like the k&n or cold air inductions ones do
Somewhere I read that if any oil gets on the MAF sensors at all it will make your car go all goofy. Any oil that was going to be sucked outta the filter would have done so by now. So from what people have said, I'd take off the MAF and spray it with MAF cleaner then it should be good.
Ive already cleaned the maf. Didnt help. Idk wtf the problem is but its really annoying when u pull out of somwhere and it cuts power off...makes it look like I missed a gear lol
Probably in your hubs or the wiring too them.. Gm sells replacement harnesses or you could fix yourself if you locate a problem.
As far as cutting out, does it do it when the wheels spin? Because that's the over reactive nanny no no stock tune.
Have you had the codes read yet? I'm having issues with my traction control, brake assist and brake system but don't have the issue with it cutting power. I've replaced a tie rod and 2 wheel bearings already and the warning messages still pop up. Prolly gonna have the codes read this weekend to see if I can narrow the problem down.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
