Fuel injector cleaning
Old Nov 24, 2013 | 05:52 PM
saltybreadstick's Avatar
Default Fuel injector cleaning
Ok so i have everything i need for my intake swap now but want to clean the injectors before i put it all together on thursday. gonna see if anyone has any advice and can also provide a kit that'll come with new o-rings and the little filter screens.
here is a write up i found on another forum...does everything look about right as far as steps go?
http://www.grandprixforums.net/showthread.php?t=79095
and this kit says it'll work with ls1 fuel injectors
http://www.bonanza.com/listings/Fuel...FWrNOgodfxIAZA
anything else i need or a better kit than that one
Old Nov 24, 2013 | 05:55 PM
o damn....just found this to. going to give them a call in the AM
Old Nov 25, 2013 | 09:33 AM
blkchevyz's Avatar
check youtube as well. i watched something over the weekend that showed a way to clean them with less than 10 dollars in parts(including the carb cleaner)
Old Nov 25, 2013 | 09:34 AM
blkchevyz's Avatar
thats the one i watched. but there are a bunch of other ones as well
Old Nov 25, 2013 | 10:33 AM
91parkave's Avatar
Moderator
Forgot to tell you I did this to the injectors before I installed them. There cleaned out the same way in the YouTube vid I watched (same as blkchevys)so total less than 5thousand miles are on them and originally 24k from the ls6 they were pulled from
Old Nov 25, 2013 | 11:07 AM
Well in that case I'll just leave em be. I'm repainting fuel rail today so got the holes plugged.
Old Feb 27, 2014 | 12:39 PM
Bigwayner07's Avatar
What about adding a fuel injector cleaner in the gas? Has there been any results? Seamfoam treatments? I'm not looking to take each injec out and clean them. Its to damn cold.
Old Mar 9, 2014 | 04:10 AM
heavyft's Avatar
2 bottles of Autozone TL-3 in the tank with 2 gallons of fuel.
