While my trans is out...
Old Jan 1, 2014 | 11:01 PM
gagt3100's Avatar
Default While my trans is out...
While my trans is out is there anything I should do? Maintenance wise or performance wise that would be easy to do while its out?
Old Jan 2, 2014 | 08:37 AM
08 pimpala ss's Avatar
Rear main for sure!!
Old Jan 2, 2014 | 03:58 PM
gagt3100's Avatar
rear main?
Old Jan 2, 2014 | 07:42 PM
The rear main seal are cars are known for leaking oil after 80k
Old Jan 4, 2014 | 02:29 PM
Suaveat69's Avatar
Replace the cradle bushings and rack bushings. Much eaiser to do it now. Good time to replace mounts as well.
Old Jan 23, 2014 | 08:43 PM
So About to pull mine what all did u do while it was out?
Old Jan 23, 2014 | 08:51 PM
gagt3100's Avatar
Just the steering rack, I would replace both trans mounts, the passenger side has no aftermarket replacement, but the drivers side one I got replaced with a poly mount from ZZP
Old Jan 24, 2014 | 09:10 AM
blkchevyz's Avatar
i wish i would of done the transmission and motor mounts.
if you havent throw a cooler on it.
