Camshaft for a o6' SS Monte Carlo
Hello,
I'm just curious about this car. I purchased one about a month ago and I would like to make some changes to the motor. Before anyone starts with is a crummy car with it being a FWD---"I GOT ALL OF THAT", but "IT's MINE"!
Camshaft, headers, and a exhaust system.
My question, is do I need to change out the rocker arms when I add another camshaft?
Hello,
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Definitely not a crummy car cam shaft is alot of work id start with intake swap then headers and full exhaust but if you cam i belive u have to change lifters and u can go with the ls9 cam and the cam wont really be worth it by it self in my opinion there is so much u can do just read through this fourm
Best way to go is to get a cam spec'd out by either CalSpeed or Patrick G. All you need to do is describe your mods and how the car will be driven, and they'll come up with the best grind for the application.
When I put the LS3 heads/intake/tb on my Camaro, I got a cam spec'd by CalSpeed, and my 480+ to the wheels has put the hurt on much more highly modded cars, including some FI ****.
Get spec'd cam and you won't regret it.
No disrespect intended, but an LS9 cam without boost is a complete waste of time. OP will be very unhappy with the results if he goes to all that work to install a cam not optimized for his application.
I think the first question to ask is, what is your budget? I did a cam, upgraded valve train, ported and shaved heads, ls1 intake, headers and exhaust and a TEP transmission. Do some reading after that if you want my old cam I will sell it to you for next to nothing. It's a 056 boss, the manufacturer has a sound clip on their web site.
And like was mentioned above, a cam without any other supporting mods (intake, head work, headers, etc.) is a waste, too.
