Intercooler + Trans cooler
I'm debating on getting a stand-alone trans cooler but need to know if it may interfere wtih the intercooler of the cartuning.ca turbo kit
I always preach standalone. Its simpler, it cuts out the risk of your radiator leaking coolant into the trans fluid.and the people talking about needing to heat fluid , well its a synthetic trans fluid(dex6). The viscosity will always be very consistent no matter the temp.
Regardless you can find bar plate style trans coolers all over amazon for 50+bucks. Nothing super hard about it. And if your worried about fittings you can use AN style fittings and hoses from the trans case to the cooler.
