abs, traction control...
http://modulemaster.com/rebuilds/sho.../abs-bosch-53/
On another note, received the EBCM back from modulemaster today, looks like they were able to correct the issue, waiting for the weather to clear up so i can get this thing installed. He even repaired the solenoid i ripped out by accident removing it. :x
Edit nevermind looked it up looks like a smoking hot deal
I diagnosed an AC problem with it. One of my cadillacs had no codes for the AC, but the AC would only run for a few seconds. Long story short, one of the temp sensors was messed up and it thought it was 32 degree's on the low pressure side causing the AC to turn off and stay off until the heat from the engine heated it back up. I was able to see the sensor reading was way off instantly when i hooked up the auto engunity. There is alot of "Bi Direction control" i do not think you can control door locks n such from it. But you can command EVAP Silniod and bunch of other stuff. I can get you an exact list of the BI direction control for my Monte Carlo, all cars will have a little differnt bi direction control. But as far as what it can read , it can read wheel speed sensors, pressure in the gas tank, etc etc. Let me know if you want to know any specifics. I also used it to diagnose a vacuum leak on my Cadillac because my fuel trim numbers where high "aka the computer was adding fuel" because the car was running lean from a "Vacuum leak" I was geting +20 on my long term fuel trims and when i would rev it to about 3,000 rpms i knew instantly it was a vacuum leak and smoked it and found it at the vacuum bulb
