DoD delete kit and LS3 valley cover
Old May 8, 2015 | 03:58 PM
spawne32's Avatar
Default DoD delete kit and LS3 valley cover
So I got my DoD Delete kit in the other day, and a bit curious about what to do with the crankcase vent on the front of the cover. Shown here in the picture below, has the red vac cap on it, anyone have any advice as to how to deal with this? Otherwise im just going to lop it off.
Old May 8, 2015 | 06:18 PM
91parkave's Avatar
Moderator
With that you would cap off the rear valve cover and use that as your primary dirty pcv lime connected to a vacuum source
Old May 8, 2015 | 07:14 PM
tim4daflow's Avatar
did you get a full set of new lifters all 16?
Old May 8, 2015 | 09:52 PM
spawne32's Avatar
Everything in the scoggin dickey DoD delete kit, havent opened the boxes yet but should be 16 LS7 lifters. Just worried about intake manifold clearance with that port being there, as its really tight on that front side.
https://sdparts.com/details/scoggin-...enter/sdafmd53
Old May 8, 2015 | 10:13 PM
superglide9375's Avatar
dam u doing everything i want to do,lol what lift cam u go with?
Old May 8, 2015 | 10:15 PM
spawne32's Avatar
It's going to be a custom cut .535 lift on both lobes, was going to run .550 lift but the machine shop called me back and told me that at .550 id be at exactly .050 clearance for coil bind. So i decided to back it off a bit. It's going to be this cam exactly with the custom lift.
http://schneidercams.com/272-78RH_LShydroller.aspx
Old May 8, 2015 | 10:16 PM
spawne32's Avatar
Here's a comparable comp with a 112 lsa.
Old May 9, 2015 | 06:38 PM
lVloses's Avatar
I just pulled the nipple off and threw some JB Weld in the hole. Been working fine for 2 and a half years now.
Old May 9, 2015 | 06:42 PM
lVloses's Avatar
You can kind of see it in the picture. You have plenty of clearance even with the FAST 92 and not hacking off the break booster nipple like most people do.
Old May 9, 2015 | 09:27 PM
spawne32's Avatar
You got a fast 92 to fit on this car?
Old May 9, 2015 | 11:09 PM
what he said?
Old May 10, 2015 | 04:08 PM
lVloses's Avatar
Yeah, with a PS reservoir relocate it's just as easy to put on as an LS6 intake manifold.
Old May 10, 2015 | 08:43 PM
dammit!
Old May 11, 2015 | 01:38 PM
spawne32's Avatar
could you post some pictures?
Old May 12, 2015 | 06:33 AM
lVloses's Avatar
I have a thread of it somewhere on here.
Old May 14, 2015 | 05:29 PM
blkchevyz's Avatar
price isnt to bad for that kit.
