LS4-to-6T75 Adapter Plate
Old Jun 23, 2015 | 01:56 PM
GXP25's Avatar
Default LS4-to-6T75 Adapter Plate
As the title states. Who would be interested in such a thing.
If I get enough people interested then we can get some made. There would be more things related to this swap to come of course.
Old Jun 23, 2015 | 02:02 PM
4x4chase's Avatar
I assume the 6T75 is a better tranny? Factory installed in what?
Old Jun 23, 2015 | 02:09 PM
91parkave's Avatar
Moderator
The 6t75 gives you 6 speeds. A way more usable PowerBar and should be able to hold most ls4s power with no issues. The power limits have yet to be explored on this transmission though. And the interface needed for the t43 vs our t42 trans controller would also be a factor as well with potentially easy solutions.
I'd love to have the six speed but again with no starter provision and uncertainty id think it'd be more beneficial to have a standard LS block architecture plate made. Grab a truck motor swap in your crank or have that one machined and have fun in your 5.3 5.7 6.0/6.2 liter beast
Old Jun 23, 2015 | 03:24 PM
x11 nut's Avatar
Any one played with a 6T80 yet? Suppose to be same casing but beefed up and rated to handle higher torque than 6T75...
Old Jun 23, 2015 | 03:39 PM
GXP25's Avatar
Correct, as seen in the XTS Vsport. However, that is AWD, probably expensive due to its limited use, and I cannot find much information on it.
Old Jun 23, 2015 | 03:46 PM
GXP25's Avatar
[QUOTE=91parkave;18856865]The 6t75 gives you 6 speeds. A way more usable PowerBar and should be able to hold most ls4s power with no issues. The power limits have yet to be explored on this transmission though. And the interface needed for the t43 vs our t42 trans controller would also be a factor as well with potentially easy solutions.
The 6T75 is alive and well behind an LS2 engine in a Fiero. It's been that way for two years now. In that aspect, the programming is complete. In fact, a new module is out there that would interface with our BCM. That means gears "5" and "6" would show up on our DIC and HUD in TAPshift mode.
Starter is taken care of and I am close to getting the template for that.
Axles, mounts, and shifter cable already exist for the 6T70 for the W-body Impala. Transaxle lines are straight forward.
If anyone could take care of this right now, it'd be bfurches.
So if anyone has any interest, let me know.
Old Jun 23, 2015 | 03:47 PM
GXP25's Avatar
Large crossover vehicles (GMC Acadia, Buick Enclave, Chevrolet Traverse) and a Fiero with an LS2.
Old Jun 23, 2015 | 04:54 PM
x11 nut's Avatar
What are you doing for a starter provision then? I have a 65 case I'm going to sacrifice to use starter boss to weld onto an 80 case... Once I'm moved into the new shop!
Old Jun 23, 2015 | 05:28 PM
91parkave's Avatar
Moderator
Wasn't the fiero using a complete standalone trans Co troller?
Old Jun 23, 2015 | 06:41 PM
rottonj's Avatar
[QUOTE=GXP25;18857050]
This is very interesting, sounds like you have been doing a good bit of homework on this. Good job.
Old Jun 24, 2015 | 04:42 AM
Mike The Canadian's Avatar
I'd be interested in this.
Not sure how much the 75's and controllers go for these days?
Old Jun 24, 2015 | 07:57 AM
GXP25's Avatar
Screw the 4T80. Are you still in South Florida?
There's a pocket in the 6T75 for a starter and the adapter plate will have a gap provisioned for the starter.
Old Jun 24, 2015 | 08:09 AM
GXP25's Avatar
Yes. A standalone controller is needed with the T43 since it's within the valve body of the transaxle. This standalone controller interfaces between the stock T42 and the T43 within the transaxle.
Old Jun 24, 2015 | 08:11 AM
GXP25's Avatar
I got my 6T75 for ~$750 a few years ago. I believe the controllers are within the $800 range, maybe more.
Old Jun 24, 2015 | 09:08 AM
Cheaper than a 4t65 rebuild!
Sounds like the only road block now is fabrication. Bfurches and x11nut seem like the guys to do this!
1st gear will be very interesting lol
Old Jun 24, 2015 | 03:21 PM
x11 nut's Avatar
I'd be very interested in seeing both the 4T80 & 6T75 become viable swap options!! The 80 would be more straight forward if / when I get the mounts sorted out, as it wouldn't need a separate controller.
GXP25, I'll hit ya offline and see what we can work out.
Cheers
Old Jun 24, 2015 | 05:08 PM
91parkave's Avatar
Moderator
http://www.tbmsport.com/6l80gm6spdinformation/6l8090eswapcomponents.html
Old Jun 24, 2015 | 06:19 PM
GXP25's Avatar
As far as I'm aware and after speaking to the owner of that site a few years ago, that's not the controller we'd want.
Old Sep 22, 2015 | 07:16 AM
Has any progress been made on one of these swaps?
Thanks!
Mike
Old Sep 22, 2015 | 12:44 PM
LSX Freak's Avatar
Also curious to know what a starter replacement would entail if this swap was done.
