speedmaster 96mm intake manifold swap thread
http://store.katechengines.com/oil-p...take-p148.aspx
I use air tools to do the porting. I have a high speed air grinder from lowes and various chucks to fit different style bits. Im using a long shank aluminum burr for the hard to reach areas that need heavy cutting, and a 20 dollar pack of catridge rolls and arbors from harbor freight. Comes with 80-120 rolls and various shapes, spiral and straight. Not really trying to reshape or remove material in the runners by the port openings, only reshaping and heavy cutting im doing is on the inner part of the manifold where the runners take in air from the plenum. There's alot of rough cast protruding in those areas, so im blending them to have smooth transitions around the curves.
http://www.ebay.com/itm/LS-Gen-4-Valley-Pan-Cover-Plate-Low-Profile-Carb-Lifter-LSX-LS3-DOD-Delete-55164-/131578184042?vxp=mtr
im going to test fit the stock rail using FAST injector hats (extenders) and a set of spacers and see if it will clear the middle of the runners. Worst case scenario a set of holley efi LS1/6 fuel rails will do the job just fine, they sell them as a kit for about 100-120.
Does this new valley cover have the tower block offs ?
