Help with electrical problem
When the car is running, randomly the battery voltage (as shown on my aeroforce gauge) will start jumping all over the place. It will drop from 14 volts down to 12.3 or then back up to 14.5 then 13.8 then down to 12 and then 14 again and so on. It's all over the place and while its doing this I can see all the lights inside and outside dim when it drops.
I have changed the alternator, battery, and made sure connections and grounds were clean and tight. I tried unplugging the battery voltage sensor, and it made no difference. I don't know for sure if that is a good or bad thing unplugging the sensor made no difference...
Any ideas? Is it worth trying a new voltage sensor?
Someone with more experience on these cars electrically will chime in I'm sure.
You could also do a big 3 upgrade to the elec system.
Anybody ever have to change the voltage sensor before?
It was doing it again today. Out cruising on the highway, I look and the Batt volts and they dropped down to 12.8 and stayed there. Looked again maybe 5 minutes later and it's back up to 14 like it should be...
Let me know if you find anything, perhaps I have an issue that's being covered up by having a deep cycle battery (hence not finding it dead).
