Recently with my GXP...
So, I'll just list what I have done first and explain a bit more in depth as I go. Starting with my exterior, it hasn't changed much. With the exception of new headlights, wind deflectors, and debadging of the Grand Prix on the trunk and the GM logos on the fenders. Also got a muffler delete, because my mufflers were rusted out at the inlets and rattling like hell. I had the tips stick out a little more as well. In addition, I also smoked out the reverse light lense because I thought it stood out like a sore dick. After countless wheel-out's and paint work, I have gotten it to almost a mirror reflection. I haven't really experimented with anything too abrasive, but for the hours and hours of buffing, I'd say it looks pretty damn good.
As you can see, I did get the CCFL halo headlights. The only running light I have hooked up are the halos themselves, along with my switchbacks in the turn signals. I was a bit skeptical with the aim of the beams and brightnes problems that ensued, but with my lower grille fogs (8000k) and the addition of a 55watt 6000k HID kit, it lights up the road exceptionally well and I feel will not require any further modification. The combination of all the lights really gets some attention.
As far as the engine/tranny goes, haven't done much. Haven't had to. The trans has been running strong, thankfully, being the fact I am at 98k now, I'm going to keep my fingers crossed and start some service/mods to it over the winter (shift kit, fluid/filter change) I check the fluid as often as I can, still looks normal with no burn smell or sign of debris/dirt when wiped on a white rag. I did have to replace the MSD wires because they showed signs of heat damage, and a few of them were causing a miss. I picked up the Taylor cable wires and haven't looked back. I notice it likes to burn about a quart every few thousand miles, I've heard this is normal for having DOD activated, and I have read into why. Knowing this, and for other reasons, I will be looking into a hand held tuner in the very near future. I've heard good things about the diablosport line of products, and the in tune is relatively inexpensive considering most of these go for a lot more. Please advise me in any way possible on this, as I'm new to aftermarket tunes and I'm wanting to learn as much as I can.
Now for my favorite, and quite frankly, my biggest acomplishment with the car to date. I completely overhauled the audio system. I spent weeks and weeks researching, and figuring out what would be best for what, ect... Here's a list of everything I installed:
-Pioneer AVH-x8700BHS head unit
-infinity kappa 6.5 components in front
-infinity kappa 6x9 2-ways in rear
-alpine PDX-F4 4 channel
-alpine 15" type r, vented enclosure, with a JVC 600watt RMS amp I had laying around. May upgrade soon.
That's the gist equipment I put in, not accounting for the wiring harnesses and such (non monsoon stock system) I went and dynamated all the doors and deck/trunk, as well. Let me tell you. I've installed a lot of systems in numerous cars, this is by far the best setup I have ever ran. Sound clarity is crystal, and the sub is just the right amount of punch without being overbearing. Power draw is exceptional, doesn't really cause any dimming unless I'm pushing it to near max and the song playing has a lot of low frequency notes. I can live with it, as I don't listen to music that loud normally anyway. Worse come to worse, there are lots of options I can consider to correct it. I'm not worried about it, I'm more than happy with it.
***Before I wrap this post up, I do have a question id like to ask. I'm getting a very strong fuel odor from the left rear area of the car. You can smell it from the inside of the car, usually getting back into it after I've driven and shut it down. Occasionally while driving, and I'll get the check gas cap warning followed by a p0442. First time it threw a p0455. I already tried replacing the cap and the canister purge solenoid under the hood. I'm thinking it's the vapor canister itself, seeing as it seems to be a common issue with these cars. I haven't had a chance to look under there, so I'm not sure if I'll need to replace just the canister or the "assembly" including any hoses needed and such. Either way, could I get away with just replacing the canister itself?
I know I may be forgetting a few things...installed BMR trailing arms as well... but overall, this has been the best car I've ever owned. It couldn't be a better, more fun daily. I'm going to be getting another vehicle for the winter to keep this thing put away from the snow, to keep miles off it, and so I can get some things done on it for real. I have big plans for her, between aftermarket wheels, struts/lowering springs, the list goes on. I have developed a strong love for the car since I bought it in February and has become something I would consider keeping long-term. In my opinion, being what it is, it is a fantastic looking car that people still can't seem to figure out what it is half the time. Lol. But anyways, thanks for taking the time to read my novel. I will try to make it a point to update more often, I am an enthusiast just as you all, just have a very restricted time schedule. Hope you all like where it's going!
Also, I highly recommend the Diablosport tuner. The car runs better, shifts are firmer and doesn't burn any oil now. After I tuned it, I also replaced the plugs and wires since the DOD plugs were pretty well used up.
As I said, I have so many plans for the car that I'm trying to work into my time schedule. It's been a joy to come on here and see what everyone else is doing with their cars, and has guided me when working with mine. I'm going to try to update as often as possible to make sure my car isn't forgotten. My goal is to be an active member of the community, offering and taking advice. I'm grateful places like this exsist on the Internet, that's for sure! Haha
if you are concerned about the difficulty using HP tuners, have no fear, there are plenty of us here who will/can assist you in making the simple modifications that DiabloTune can.
https://ls1tech.com/forums/ls4-perfo...rk-tables.html
