Plugs?
Old Jan 5, 2016 | 05:40 PM
gilroy222's Avatar
Default Plugs?
The gxp is overdue for plugs. What do you guys like? Or are the ac delco good enough?
Old Jan 5, 2016 | 07:38 PM
spawne32's Avatar
TR5GP if your bone stock, or TR6GP (5141) if you are modified
Old Jan 6, 2016 | 02:26 AM
91parkave's Avatar
Moderator
Tr6ix
Old Jan 10, 2016 | 12:24 PM
gilroy222's Avatar
I've been seeing a lot of the TR6's now... I only have the basic bolt ons... is it still worth it to change to those that are a heat range cooler?
Old Jan 10, 2016 | 12:40 PM
Montecarloss06's Avatar
You should stick with the regular iridium AcDelco plugs since there going into a ls4.
Old Jan 10, 2016 | 09:14 PM
CrimsonGXP's Avatar
I also think ngk has a good iridium plug. Thats what I went with along with a set of msd wires. Ran a lot smoother after. Was getting misfire codes on a scan tool before.
Old Jan 11, 2016 | 12:50 AM
91parkave's Avatar
Moderator
Because it's a ls4 is irrelevant, stick heat range and the amount of timing on a stock motor makes it knock alot. The tr6ix help oUT alot in fighting kr
Old Jan 11, 2016 | 10:26 AM
superglide9375's Avatar
tr6 is what i use and i tried them all with 234k on car lol
Old Mar 6, 2016 | 03:55 PM
1speeder's Avatar
will NGK tr5ix work well ?
Old Mar 7, 2016 | 06:20 AM
yep,used those before 6s
Old Mar 9, 2016 | 02:52 PM
06MonteSS's Avatar
LS1Tech Sponsor
NGK tr6ix plugs and ngk or ac delco wires...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Mar 9, 2016 | 05:39 PM
Where u been lew?
