LS2 Intake manifold and LS7 maf swap thread
#48
So im stilling getting engine power reduced when I go to the floor and release. With the new wiring setup, the throttle position now matches the the desired position, just not sure whats setting off the code. P1516 and P2101, if i remove the codes from the diagnostics, it still goes into engine pwr reduced, and I have to clear codes that arent being read by hpt.
#50
![](http://www.hostthenpost.org/uploads/e42a0f8fd30a6b4e27a6c0db41d467ac.png)
For all intents and purposes, it seems like the throttle isnt snapping back fast enough or binding on the way back, so the desired position is different from the actual. I also found this data for the LS2 throttle bodies, but I would need LS3 pinouts to verify that its using the right TPS voltage range as the two seem to be opposite each other on the 8 pin setup.
![](http://www.hostthenpost.org/uploads/935c2c57c58cf6e00a92761ddb5d29a6.jpg)
Do you have this LS3 tb on your car? Im curious what your min/max voltage is.
#53
Moderator
Exact same codes till I disabled them. Then tore it apart and found that I had a slight bind. Pretty much as you described , that was with the ls2 I had. After I cleaned the bore a little which I just attribute to manufacturer tolerance a little to far out of spec, I never had a issue afterwards and re enable the codes with no issue. I tested the ls3 once I got it to make sure as well and zero issues in the time I've had it. Guess it's luck of the draw.
#54
#57
Right, I did go back and rewire it again this morning and the throttle position and desired throttle position in HPT now match up correctly. However I do not have a TN colored wire at PIN C on my oem connector, i ahve RD/BLK. However I followed the same pinout setup and ignored the colors. I think that if it was wired improperly it wouldnt even drive at part throttle.
