Free MagnaFlow exhaust system
I think I'm just going to do like eddiemoney said and take it down to the local exhaust shop and have him put it in and weld it up. I've dealt with him in the past and he does good work. I need to remember to tell him about the tailpipe though. I dont want mine sticking out past the bumper either.
Sticking big things past a defined vertical surface such as the MCSS's looks ricer / pimp. I still consider having my extra 3" rolled stainless tips I have in my garage welded on the MF tails in place of the tips supplied as to not get in the debate of "my tail pipe is bigger than yours". To me subtle / clean is better.
I see the Imp has a different bumper. The Impala also gets a different tailpipe assy. The vid on the Magnaflow website looks like it may fit design harmony on the Imp, but there's not a side view to reference. Under the rolled bumper, the MF tails should look "non-stock". Just double / triple check / sleep on it before you set the tails. Look at it from the side, and follow the style line of the bumper - as long as the tails don't go past the vertical plane of the bumper and look like something you can step on to get into the trunk you should be OK.
I'm more in line with the Car and Driver mentality. But, some would disagree with me, so it boils down to whatever you personally like.
I think the ramps will be my next purchase. I can't stand the sound of the jackstands crushing the metal around the jackpoints on either of my cars.
BTW - I only jacked the back of my MCSS up, maybe a foot or two off the ground. I was able to reach the center of the vehicle easily. So, to back up the ramps in the rear of your car would duplicate me jacking up the rear only.
You may want to disable the DoD, and remove the resonator to get the V8 rumble you're looking for. I think the resonator is there to dull the 4-cyl sound.
http://ls1sounds.com/magnaflow.htm has clips of MF systems on F-Bodys, which sound like just about any other high-perf system. Listen to the 5th one for a fly-by.
But, I still need to have one of my friends drive my car away from me to hear what it sounds like from outside the car.
I had a 99 Tahoe before this and I had dual in dual out magnaflow muffler on it with the pipes going out the back. It sounded SOOOOOOOOOO good. Cruising, idling, getting on it, it was wonderful. Wasnt too loud, but deep and aggressive. I guess I was used to that and had it in my mind that this would be close to that. Two totally different setups though. Maybe it'll grow on me.
I must record now. It has been broken in with 3000 miles since I installed them.
I want to change my tips, because they are double-walled right now, and making weird noise(like vibrating noise). I think single-wall makes better sound. Tips make final sound of the exhaust. Long or short, small or large. All make different sound.
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Tips are like horn. the longer pipes are like pipe organ effect, the deeper. The little inch longer tip might double the sound because of the wave length. The little inch longer tip might not change at all. We have to experiment these stuff. To do that, time and $$$
Stick with Borla or Magnaflow for good throaty sound on a smaller motor like the LS4
