Free MagnaFlow exhaust system
4
Your PM box is full so here's the message I attempted to send:
I was just wondering if the GXP exhaust ('06) was finished yet. Someone at clubgp.com had called Magna Flow and was told it wasn't available. However, HERE is a link showing Magna Flow's system installed. Any help/info with this would be appreciated.
http://s13.photobucket.com/albums/a2...t=MVI_4925.flv
The system has 11K miles on it now, sound to me is dead on for the car, but won't intimidate anyone yet.
Maybe I won't remove the resonator after all.
Oh, yeah...and the wife absolutely hates it to the point where she may never choose to drive it unless it's absolutely necessary. Yeah, that's good and all...but i guess i'll be doing a lot of shopping on my own from now on. I hope it tones down a bit when i install the P/S tip which is currently being worked on by Midas...maybe that will make it a bit bearable for her.
I really hate shopping when it's not for my car.
I had a small BSR issue when I hid the clamp that connects the Y with the pipe after the resonator, the clamp bolt was hitting the shield. Had to rotate it so the bolt was visible from the side.
You can manipulate the system by leveraging the mufflers up or down and side to side, as well as not inserting the driver side muffler assy all the way in the pipe. I just lightly clamp the system, then push it into position and then clamp it tight.
My mufflers hang straight down from the body mounts, but all vehicles are not always assembled "true".
Your wife's issues will go away when you put the tail on your car. It will allow the sound to exit at the end of your car, not underneath it and bounce around. If not, you have achieved true "guy car" status w/ your Imp if the wife or G/F won't ride in it.
(that also "naturally happens" after a few years of marriage anyway
) I haven't had time to get under there and adjust the whole thing, but i'll get to it. In order to make the right side tip line up with the cutout i had to move the muffler out on the "Y" about 1"...but b/c it's a "Y" and not a "T" it also pushed the tips out another 3/4" from the bumper. Oh well, i'll be tinkering with this for a while, i can already tell.
However, i better get this welded up soon before i come out one morning to find the tails (and maybe mufflers) are gone!
I need to make some serious adjustments. I found some Magnaflow tips (see the other thread) that are comparable to the MBRP ones i showed you, and they're only 10" long (but 3" ID)...I actually think the 3" ID will help me to set them farther back (towards the muffler) on the tailpipe and therefore be workable.
Granted, i'm usually at 11-12 with all hard City driving...tons of stopsign-to-stopsign driving with moderate acceleration...but i'm hoping someone accidentally reset the AVG. ECON gauge while driving.
I'm going to fill up today and reset the DIC, but this is not a good sign. I haven't even been any worse on her than i usually am. I think it's time to take off the K&N and go back to stock for the winter
It's been around freezing here and i don't think i need any cooler air than what the stock would give me.Also, taking off the K&N will allow me to take it into the dealer (again) to have them check it out. I'll also try cleaning the MAF before i completely remove the K&N.
www.PerformancePeddler.com has it for $528 when you enter promo code "GOOGLE4E" and free shipping
EDIT: "CLUBGP" got it down to $610. You can call SummitRacing or somewhere else and tell them that you're looking for the best deal and can get it at PP for $610. Remember that while it's free shipping there too (summit), they charge a "handling fee" of $10, so factor that in your cost as well.
