Looking into a 2007 GXP, Pros vs. Cons?
What are its issues? I hate the idea of the tires being different size WTF is that for?
Jim
Tony
Here are 2 really good threads from several months ago. The first has several pictures and the second has some reviews of the car from several of us GXP drivers.
https://ls1tech.com/forums/ls4-performance/456686-pics-gxp-s.html
https://ls1tech.com/forums/ls4-performance/487454-how-do-you-like-your-ls4-cars.html
The front tires are different size exactly for the reason someone else said. The program team had a lateral G objective that could not be met with a compound of tire that was realistic. The rear tire/wheel can't get larger because of the underbody, trailing arm and quarter panel lip. You can run a bigger tire/wheel, but under some circumstances you will get contact. The trailing arm is specific for this vehicle for clearance and a friendly surface for the tire if contact occurs.
The front tires could get larger because a GTP specific fender was used. The wheel offset sets the tires out far enough that they won't contact the cradle. Also the staggered size, larger front than rear help control understeer.
W-cars are very good cars, there are no specific "problems" with these cars. If you want to drive over 140 you will have to look elsewhere! Also you can't run 140 sustained, the car will continue to slow itself down to avoid possible overheating.
Brian
Brian
To the best of my knowledge, a W body is a Corporate body which means its used through out the GM line up. Not like they would have fender wells in the rear that were more shallow than the Impala?
Its like a Camaro and Firebird, swap the body panels and various interior components and you can make one into the other.
Its just been my understanding that the GXP was the "performance" vehicle and got all the neat little tweaks like the tap shift and such. And now the difference in tire/rim sizes to differentiate its handling characteristics from its stable mates, the Impy and the Monte.
A 235 will fit a GXP, but the tire envelope shows in some instances you will get contact. Because of the high volume of sales on these cars the tire envelope was pretty conservative to not cause issues.
Anyway, for whats its worth that is why they have different size tires front to rear and why the Impala was able to go with a 235.
Brian
