Torque converter options?
Old Feb 15, 2007 | 10:37 AM
Reckless's Avatar
Super Moderator
Default Torque converter options?
Is anyone making a higher stall converter for these cars? Or is there an alternate GM 258mm converter that has a higher stall?
We are stuffing an LS4/4T65E setup into a Diablo replica (Fiero chassis). We will be eliminating the D.O.D. and adding heads and cam.
Old Feb 15, 2007 | 02:08 PM
Area47's Avatar
zzperformance.com
Old Feb 15, 2007 | 07:21 PM
Reckless's Avatar
Super Moderator
All I see is converters for the 3800 engines there? The LS4 is a 258mm converter, not 245mm.
Old Feb 15, 2007 | 09:26 PM
Compg's Avatar
The LS4 is mated to a 4T65-E(HD) just like the supercharged 3800s. Yes the LS4 and SC3800 uses a 258mm converter and the ones they sale are 245mm(N/A 3800 tranny converter). You have to drill you flexplate to mount a 245mm converter because the stock holes do not line up. Or just buy one from ZZP at the same time for all of $40. People do it every day in the SC3800 world with the same tranny so I think you will be alright.
Tate
Old Feb 16, 2007 | 08:57 AM
eddiemoney's Avatar
I would agree with this statement. I would just purchase the convertor and flex plate together and i think they will drop in.
Old Feb 16, 2007 | 12:17 PM
live2ride's Avatar
The stock converter stalls pretty high with the LS4. How much more would you expect from the smaller one with out changing heads and cam?
Old Feb 16, 2007 | 01:04 PM
Reckless's Avatar
Super Moderator
We are not going radical with the cam, so I think we will see how the stocker works and go from there. Thanks for the answers!
Old Feb 16, 2007 | 04:05 PM
BADDLS1SS's Avatar
Go with a pretty mean converter if your gonna change it... Stock is NICE to me and pretty loose. They are about 3200 stall or so.
Id go 3800-4000 with a mid 2 STR, should be enough to be a mean **** down low, but you will give up roll racing punch as the looser converter is more inefficeient at transfering power at those speeds.
