More rocker arm stuff.
Old Jan 22, 2008 | 09:03 AM
Area47's Avatar
it picked up at the higher rpm range where it needed it. the power didn't fall off like it did with the stockers
Old Jan 22, 2008 | 08:35 PM
Nacho SS's Avatar
Originally Posted by TiredGXP
Out of curiosity, did you check your piston to valve clearance during the install?
Don't know if anyone has posted up the results of such a check so far, but it would be nice to get a rough idea how much room there is.
No I did not check with a gauge, but I eyeballed it and compared to it to a 5.3 PRC headed LS1 that we were working on at the same time....they had good clearance.
Old Jan 22, 2008 | 08:59 PM
98Jeep360Limited's Avatar
So, my car will pull noticeably better above like 4500 rpms with the rockers and high flow cat? It does pretty good now, but more certainly wouldn't hurt
Old Jan 23, 2008 | 07:19 AM
07gxpgray's Avatar
Originally Posted by Area47
mine that i had were much easier
put on, set to 22 ft lbs, turn motor over, go
So you just had to install yours, tighten and go? No rotating the engine?
Old Jan 23, 2008 | 09:12 AM
Area47's Avatar
Originally Posted by 07gxpgray
So you just had to install yours, tighten and go? No rotating the enine?
well, unplug the injector harness, or fuel pump relay. turn it over a couple times. listen for odd noises. no odd noises. fire and let it idle for a bit. the clatter will go away. enjoy the fun
Old Jan 23, 2008 | 10:06 AM
07gxpgray's Avatar
Thank you
So harlan sharps...for any LSx engine right?
Old Jan 23, 2008 | 01:18 PM
Area47's Avatar
yulp
http://store.summitracing.com/partde...8&autoview=sku
Old Jan 23, 2008 | 01:56 PM
07gxpgray's Avatar
all you changed was the rockers...nothing else - not the springs like otheres have done?
I am wondering if i can do this without voiding my warrenty....i mean they probably wouldnt know, unless they have to open the covers...right?
Old Jan 23, 2008 | 02:09 PM
Area47's Avatar
you got it.
tom/baddss did a write up on it somewhere on here with part numbers and everything on what he did. he posted the part number, so i just got the ones he put on his monte which i believe is that part number i posted above.
