t-stat and housing
Old Jul 21, 2007 | 09:04 AM
djfeezy's Avatar
Default t-stat and housing
Has anyone looked at this t-stat and housing? http://www.vincihiperformance.com/lt1coolingparent.htm Have any opinions on it? Good, bad?
Old Jul 21, 2007 | 12:05 PM
Nacho SS's Avatar
Pain in the butt to install, but some people will say its a good mod.
Old Jul 21, 2007 | 01:39 PM
Taz34SS's Avatar
It says that it will not fit the 06 Impala SS? Will it work on the 07 Monte or nothing in 07?
Old Jul 21, 2007 | 03:28 PM
djfeezy's Avatar
Read it again. It says that it will fit the 06 impala ss.
Old Jul 22, 2007 | 09:58 AM
Taz34SS's Avatar
THE PREVIOUS THERMOS WILL NOT FIT THE 2006 IMPALA !
Ahh, thats what got me when I read that from the website. I am going to be looking at ordering one of these once I can get a Predator tuner for my car.
Old Jul 22, 2007 | 10:16 AM
djfeezy's Avatar
Is there any benifit to upgrading to this housing? I plan on changing my t-stat anyways but don't know if this housing is better than the stock one or not.
Old Jul 22, 2007 | 04:24 PM
Nacho SS's Avatar
The stock thermo is a 165* right?
And this is a 170* one, I would looking into stepping up into a Ls2 180* thermo if you are going to do this install, which is a lot of tough wrenching. I would want to upgrade higher if I am going to do this.
Old Jul 22, 2007 | 06:39 PM
djfeezy's Avatar
I thought the stock t-stat was 188 or higher. Also, why would you want to go higher? The point to doing this mod is to get the engine cooler. To do that you would need a lower temp stat.
Old Jul 22, 2007 | 10:00 PM
Nacho SS's Avatar
Crap....I went backwards I think....the Ls2 one is a 160* i think.... I'm an idiot.
Old Jul 22, 2007 | 10:45 PM
djfeezy's Avatar
Yeah the ls2 is a 160. How would this stat work in the winter? My car is a daily driver and we do get snow here in the winter, ie. colder temps. Kinda the reason I was thinking about the 170 stat. Any ill effect to running the 160?
Old Jul 23, 2007 | 04:07 PM
Nacho SS's Avatar
I think BADDLS1 or Kaz has one....I would PM and ask them.
Old Jul 30, 2007 | 10:19 PM
silverGXP's Avatar
Just a FYI I just put a 160 t-stat in the car today now I have a SES light on and code P0118 i think, Low operation temp. somthing like that what can I do?
Old Jul 31, 2007 | 12:21 AM
Nacho SS's Avatar
You could have a dyno tuner dyno-cancel the code or disable it through HP tuners.
Old Jul 31, 2007 | 06:32 AM
Compg's Avatar
Pull the negitive battery cable for about 15 minutes to clear the code out. I should stay out. I've been running a 160* for a year now in my GXP with no problems what so ever.
Tate
Old Jul 31, 2007 | 05:33 PM
Nacho SS's Avatar
Tate
I have heard that only clears the code for a period of time...but once the engine senses the t-stat problem again, it flashes the same code .
Old Jul 31, 2007 | 05:51 PM
Sint3k's Avatar
Theres a reason the engine has to reach a certain temperature... When the engine heats up the valves and head reach a certain clearance. If you run the engine cooler then you have higher clearances. The LS4 engine has even tighter clearances due to complaints about piston slap and to prevent the pistons from slapping into the cylinder wall they coated the pistons. If you run at a lower temp your just risking exactly what they are trying to prevent.
Old Jul 31, 2007 | 05:54 PM
Nacho SS's Avatar
a 160* t-stat is well within the operating limits you describe of the car. They are stock on a GTO, same LSx engine.....
Old Aug 1, 2007 | 03:45 PM
silverGXP's Avatar
Ok, a day after I put the stat in the car the light has now gone off on its own. So we will see how it goes.
