LS4 Heat Soak Reduction Kit
I have had the vector one on mine since they became available. I ran it through my CAI box (there is a little notch that is just perfect fit for the wire loom to go through into the box. I think it has been about a year or so now, no issues with water or snow or anything.
Definately makes the IAT change quicker than stock. When I watched it on the HPTuner gauge screen (I figured out how to do that part - yay me!), it adjusts all the time.
Unfortunately, I have not had a chance to watch my IAT stuff since I got my Inferno hood on, so I cannot tell you how much of a difference a hood with heat extractors and none of that fireproofing under it has made a difference. Car feels like it pulls better now than it did last summer, but that could be a lot of things (I am just at 7330 miles on the car now, engine could be settling, new hood weighs about 1/4 of the old one, the heat extractors, the IAT sensor, combo of the above).
This will NOT make any more power on your vehicle. It's like how your vehicle runs better when it's cool out side versus hot. This sensor just reads every couple of seconds and adjustments are made then vs. the stock sensor reading every 12-15 seconds and making adjustments.
Tate
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
but.. with the same current conditions, hot weather, but with the new IAT sensor and it's relocated to the front of the car, getting cooler temp readings faster, the IAT now only registers say 85 degrees - so now NO timing is being pulled...
then you ARE getting better performance from it, even though you're in the same exact weather conditions.
make sense?? or am I not getting it??
see, I always knew I was right...
P/N: MSD-2320
P/N: MSD-2320
