Battery disconnect
Old Aug 1, 2007 | 03:04 AM
npd4432's Avatar
Default Battery disconnect
After reading some threads on installing new parts it was suggested to disconnect the battery for 20 minutes to clear the pcm. I recently did this and WOW. The car runs much better from shifting to throttle response. The car has 9,000 miles on it now and hasn't run this good since I bought it. When I did buy it from the dealer it had 900 miles on it, my question is did the 900 miles I didn't drive the car "learn" the previous drivers habits? Is it recommended to clear the pcm on occasion to "re-learn"? The only part I have installed is the CAI air box.
Old Aug 1, 2007 | 11:49 PM
npd4432's Avatar
bump??
Old Aug 2, 2007 | 12:04 AM
Corny40's Avatar
06MonteSS should have some info about this. I don't think he's been by today, but when he sees this, I'm sure he'll chime in.
Old Aug 2, 2007 | 08:27 AM
06MonteSS's Avatar
LS1Tech Sponsor
yeah, I disconnect my negative battery cable periodically...
it helps to clear out all the "learned" parameters, such as the fuel trims, amount of air flow, driving "style/habits", etc etc... gives it a good pick-me-up... it's especially recommended when installing a CAI, so you can reset the MAF learned parameters and let it relearn the new amount of airflow coming in...
which reminds me, I'm about due for another reset...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Aug 2, 2007 | 12:07 PM
npd4432's Avatar
Thanks, I just installed the vector HSRK, do you think I could use another reset?
Old Aug 2, 2007 | 12:30 PM
06MonteSS's Avatar
LS1Tech Sponsor
no, you should be good to go... that takes instantaneous readings and adjusts things as needed on the fly...
__________________
Old Aug 2, 2007 | 03:15 PM
Nacho SS's Avatar
Yeah regular disconnects help the PCM from getting stuck in a perpetual habit of learning your driving.
Old Aug 6, 2007 | 09:37 AM
06MonteSS's Avatar
LS1Tech Sponsor
actually, when I went to do mine this weekend... I found an easier way... dunno why I didn't think of this before
in the under-hood fuse box, I just pulled the ECM/TCM 15-amp fuse for 20 minutes and then put it back in... did the same thing... WOOHOO!!
the diagram showing the location is on page 5-97 of the owner's manual...
there are 3 fuses that reference the ECM, but I only pulled the one fuse labeled ECM/TCM - it's located right under the big STRTR relay...
when you take that fuse box cover off, you'll notice on the right edge of the fuses that there's a little white fuse puller... you'll need that! push the end of that onto the fuse and it will clip on... pull the fuse, leave the fuse in that puller, and after 20 mins, put the fuse back in - squeeze the end of the puller to release the fuse from it.
__________________
Old Aug 6, 2007 | 03:49 PM
Corny40's Avatar
Where would our cars be w/o you Lew?
Old Aug 6, 2007 | 03:57 PM
Nacho SS's Avatar
I was trying to figure out what that white thing was (fuse puller) for 20 minutes the other day .
Old Aug 6, 2007 | 08:54 PM
06MonteSS's Avatar
LS1Tech Sponsor
are you crackin' wise, cupcake??!!!
(yeah, just watched Night at the Museum again LOL)
__________________
Old Aug 7, 2007 | 01:13 AM
Corny40's Avatar
Actually, I was being serious.
Old Aug 7, 2007 | 01:17 AM
06MonteSS's Avatar
LS1Tech Sponsor
I know.... no harm, no foul...
I was just tryin' to be funny a'la Mickey Rooney...
__________________
