Need Help A.S.A.P please
Cheers,
Is that timing stock???? I have never seen that much timing stock on a LSX motor!!! Even a lot of the tunes I do can not run that much timing.
I also see it has a touch of park retard already. What gas are you using? I would be using huskey/Mohawk. I think we will be hard pressed to make
Any gains on the WOT tuning from what I have seen.
And I have no tuning done on my car!
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
I know you will gain at least 15 hp with a tune, this would be in addition to your mods. Plus firm up the trans shifts & reduce/delete the upshift torque reduction. Also I can set up the DoD to stay in V4 mode at highway speeds for a large gain in fuel economy. You car will be totally different after I tune it. I charge $600.00 for a complete tune using a wideband. Were are you located?
According to K&N, you get 10-13 HP with the CAI, so if the tune gets you another 10-12 HP, you should be right around 25. Right?
Tate
If you plan on paying someone else to tune your car, you essentially wasted your money, unless I'm missing something.
stupid diablosport. For instance, i was heading up to the mountains for my vacation last month and realized i was getting 12mpg towing my trailer with the 93 octane Diablo tune. I stopped at the first rest stop, plugged in the Diablo, reverted to the stock tune, and gained 4mpg the rest of the way. If i was using HP, i'd be stuck, b/c i wouldn't have thought about bringing my laptop with me...but the trusty Diablo handheld was tucked away nicely under the back seat.
Anyway, scarlett...find someone else, or just play with it yourself. You'll get the hang of it eventually.
EDIT: Took me a while to get this post submitted...stupid WORK...glad you figured it out, though.
Area knows his stuff, but don't you live in Canada?
