What would you do with 800 dollars?
Old Aug 27, 2007 | 11:29 AM
Corny40's Avatar
Originally Posted by DropkickdSS
No way in hell... maybe with some old beater, but there is no way i'm trusting my baby with some hack-job yokel muffler shop who will be using aluminized, non stainless piping, off-brand mufflers, and welds that might last the winter...not to mention they'll probably scratch my car and try to 'test' drive it... screw that... im paying the money for the magnaflow and doin it myself...
He said a good shop. What? They don't have any good exhaust shops where you're from?
There's plenty where I'm from and I got my "custom" system done for right about $500, less than you'll find any cookie cutter system for anywhere else. And, it sounds better than any system you'll get off an assembly line.
Old Aug 27, 2007 | 11:50 AM
427Cya's Avatar
3 sexy midgets and a bottle of crown....
Old Aug 27, 2007 | 01:22 PM
eddiemoney's Avatar
Originally Posted by Kazmaniac
Eddie - does she know what a "SS" is?
Not sure. .. . but I think anyone can be taught to respect one
Old Aug 27, 2007 | 01:47 PM
Mels SS's Avatar
Exhaust
Old Aug 27, 2007 | 02:15 PM
DavidGXP's Avatar
Whats wrong with the stock springs, the rev limiter kicks in before I go into valve float and I can't rev past 6100 anyway. 15-20HP at the wheels seems unrealistic unless we go with a higher ratio/lift rocker arm which would/could require a better spring.
Don't get me wrong, bolt on stock ratio RR's seem to be a good idea but I've heard that aluminum bodied rockers wear the main body out and send aluminum debris through the engine. Stainless steel would be the way to go but they cost bucks!
I'd like for some one to check the accuracy of the stock rocker arms, cause I know that the older V8's used, **** poor quality stamped steel rocker arms that were not a true ratio. The LS engines use a cast main body with a roller bearing right?
Thanks for the ideas!
Old Aug 27, 2007 | 03:14 PM
scarlett's Avatar
Never heard about this?
I have the Crane 1.8's and stock springs are fine, I always shift at 6 grand any ways. You can change the rockers and add springs for a little more gain. But the new springs really wouldn't work to there potential until you change the stock cam.
Old Aug 28, 2007 | 09:29 PM
ImpalaSS07's Avatar
Sup guys, I'm new to the Impala world, and really want to get in and get some more power out of this thing. I've been reading some other threads, but can someone fill me in as to why I need to upgrade the motor mounts? Also which programmer is the best bang for the buck?
Old Aug 28, 2007 | 10:40 PM
Nacho SS's Avatar
about the motor mount, there's numerous threads on that process.
As for the programmer, if you interested in learning how tuning an engine really works, use a laptop for HPTuners.
If you are a plug and play guy, get the Diablosport programmer, loads good tunes through the service port under the dash...quite easy and 06MonteSS and BuffaloSS can help you out.
Old Aug 29, 2007 | 09:11 AM
ImpalaSS07's Avatar
Ok I'll try and search somemore. I think the Diablo is more along the lines for what I'm looking for.
Old Aug 29, 2007 | 09:23 AM
Kazmaniac's Avatar
Yah, I posted a couple pics of a before and after, suitable for framing.
Old Aug 29, 2007 | 01:15 PM
20SS07's Avatar
ImpalaSS07, while the Diablosport would be better for you if you're not too sure on tuning it yourself, unfortunately it's not yet available for the 07's. I'm patiently awaiting it to be available though haha.
Old Aug 29, 2007 | 03:02 PM
  #32
ImpalaSS07's Avatar
Crap, o well guess I'll just flip my mm and get a intake for now, lol. My wife drives it everyday so she is real picky on exhuast, got to find something thats not to loud.
Old Aug 29, 2007 | 03:56 PM
  #33
Corny40's Avatar
Then get the Magnaflow.
Old Aug 29, 2007 | 06:50 PM
  #34
Nacho SS's Avatar
Well there's that or custom system.
Have you thought about a electronic cutout?
Old Aug 30, 2007 | 01:09 PM
  #35
ImpalaSS07's Avatar
Yes I have, might be the route we go with. I personally wanted 2 40 FLows on it, but she did seem to like the magnaflow when I let her hear a exhaust clip.
Old Aug 31, 2007 | 10:12 AM
  #36
Area47's Avatar
did you buy a stripper pole?
if not, come back when you do
Old Sep 1, 2007 | 04:03 AM
  #37
DavidGXP's Avatar
A 3" down pipe into the stock converter with some more 3" pipe into a cutout would be very cost effective! Around 300? Mufflers would be mostly for sound if you keep the rest of the stock piping, and dual tips are expensive !!
Old Sep 2, 2007 | 09:15 AM
  #38
Taz34SS's Avatar
What about a Fast intake Manifold? I have been trying to figure out if an LS2 fast intake will work on the LS4's or not?
As for the Magnaflow system... LOL Yes, its nice, but too damn quite. Get that, but I would replace the res that comes with it with a custom Hogan straigh pipe. Get the K&N CAI, and also get the HP Tuners and tune your car. Then add the downpiple from hogan and you will be set for alittle bit.
I am going to be working with the guys from Vinci Hi-Performance on a rocker arm/push rod, LS6 spring set up soon.
Old Sep 2, 2007 | 03:52 PM
  #39
Nacho SS's Avatar
I think we determined that Fast 90/90's dont work because AFAIK, our block is 13mm shorter than a LS2 block.
Old Sep 2, 2007 | 07:41 PM
  #40
Taz34SS's Avatar
That sucks. I really wish someone would make more aftermarket parts for our cars. The LS4 has been out since 2005 and will be in the 08 GXP and Impala SS along with another Buick car I believe.
