What would you do with 800 dollars?
Old Sep 4, 2007 | 12:35 PM
  #41
Taz34SS's Avatar
I just found out that the Fast intake will work on our cars. I am going to order one and put it on. I will let you guys know what I find out when I install it.
Old Sep 4, 2007 | 01:14 PM
  #42
hexxLS4's Avatar
What is this exactly? Got pics?
Old Sep 4, 2007 | 01:21 PM
  #43
Taz34SS's Avatar
http://www.fuelairspark.com/Products...ntake_90mm.asp
Old Sep 4, 2007 | 01:58 PM
  #44
hexxLS4's Avatar
SSweet!
Old Sep 4, 2007 | 02:22 PM
  #45
scarlett's Avatar
Who told you this would match up with the LS4?
Old Sep 4, 2007 | 02:29 PM
  #46
Taz34SS's Avatar
I was talking with Max at Fast and he asked me to measure my Intake and their compaired it to theres and it matches up. Also, my speed shop guy called the GM dealer to as for the part number for an intake Manifold for an LS4 and I guess its the same part number as a LS2.
Old Sep 4, 2007 | 02:32 PM
  #47
hexxLS4's Avatar
If it does work, I wonder how easy it will be to bolt on.
Old Sep 4, 2007 | 03:50 PM
  #48
Taz34SS's Avatar
Should be as easy as taking off the TB and the 8 bolts holding down the intake now, replacing the gasket and putting the new one in, bolt on the TB and remap the computer.
I think...... But I "didnt" stay in a holiday inn express last night.
Old Sep 4, 2007 | 08:12 PM
  #49
Nacho SS's Avatar
Sweet...Make sure you write it up with lots of pics, because I heard it can't be done.
I'm excited oddly...
Old Sep 5, 2007 | 02:01 PM
  #50
DavidGXP's Avatar
I'd go with the 78mm one but for 900 bucks I'll pass. Some gears, a manifold with some headers wold be sick!
Do we have to use LS4 heads? If so then whats the difference between the LS heads
Oh and check this **** out!
http://store.summitracing.com/partde...2&autoview=sku
Old Sep 5, 2007 | 02:21 PM
  #51
DavidGXP's Avatar
Old Sep 5, 2007 | 08:14 PM
  #52
Taz34SS's Avatar
I dont think that would work becasue of our shorted crank shaft. I think.......
Old Sep 5, 2007 | 08:20 PM
  #53
Nacho SS's Avatar
Nope that wouldn't work. We have the good 253 casting heads though.
Old Sep 6, 2007 | 01:12 PM
  #54
DavidGXP's Avatar
https://ls1tech.com/forums/ls4-performance/556077-information-ls4-dod-4t65e-hd.html
Heads should work just fine since the blocks the same as an LS2
Trick flows got a nice cam and head package as well, with smaller intake runners and combustion chambers. We'd need a new tune for sure of course.
Just imagine us using a Cam and head package with a performance intake, headers, converter and gears. Hp tuned with 3" exhaust split into dual 2 1/2 pipe.
Old Sep 6, 2007 | 04:17 PM
  #55
alex94z's Avatar
Originally Posted by DavidGXP
https://ls1tech.com/forums/showthread.php?t=556077
Old Sep 6, 2007 | 05:50 PM
  #56
mikeroot2's Avatar
Old Sep 6, 2007 | 06:48 PM
  #57
06 SS's Avatar
STOP! read this first; https://ls1tech.com/forums/ls4-performance/679851-f-s-t-manifolds-ls4.html
while the external dimensions may be the same and a TB will fit, the DoD oil control system sticks up too far to let these work as well as having some of the connections in the 'wrong' place.
Old Sep 6, 2007 | 11:06 PM
  #58
Nacho SS's Avatar
Originally Posted by 06 SS
STOP! read this first; https://ls1tech.com/forums/showthread.php?t=679851
06 SS saves the day...whoosh
Old Sep 7, 2007 | 05:59 AM
  #59
DavidGXP's Avatar
So tune the DOD out and replace the lifters.
It's only a mater of time before someone figures all of this stuff out. This is what car crafting is all about
Old Sep 7, 2007 | 07:33 AM
  #60
hexxLS4's Avatar
Or has the ***** to...
