Wapring Rotors on 06 Impy SS
Also, just in case, if you keep warping rotors, make sure you torque the wheels down even. If not, you risk the chance of rotor warpage due to uneven pressure against it.
Some pics would be nice.
I'll take a PM with a link in it too. Thanks!
Again, these are Ebay rotors, you can find them here:
ACUAuto Rotors
They sell them as Front and Rear sets, or just Front. These are cross drilled only. I personally wasn't looking for slotted rotors, I was mostly interested in brake fade, warping and heat. It's debatable I know, but this is what I wanted.
Anywho. These rotors are apparently made from AutoStar blanks, I don't know much about them, other than this was the box they came in, with the original part number.
I ordered mine plated and hub painted. The hub paint was useless, and kinda thin, I wouldn't recommend it really, but its neither here nor there. The plated at first seemed useless as well, during the bedding of the rotors, they looked like **** at first, and were a bit noisy. These rotors aren't completly smooth at first, and will take a couple days to fully smooth out. With that said, I took them through a mountain run right after doing a proper pad bed in. They still did great, and I didn't have any fade or issues otherwise even though they were a bit noisy.
Now that I've had them for about 4k miles or so, they are as quiet as stock. With only occasional squeaking while backup up when they are cold. The design of the rotors is the common radial pattern from center. They have what looks like a divot around the over all hole, then as smaller bore afterwords. I haven't had any issues with rusting or otherwise.
Again I'll try to get better pics later. The last two were taken tonight (yes it's dirty as hell). The first one, is the day I installed, you can look closely and see that they were a bit rough at first.
As for ACU, they were okay. Given that I requested plating and paint, they took about 3 days to process. They don't really communicate with you unless you prompt them first. Not the best Ebayer, but not the worst. The parts got here, and I was happy.
Sorry for the long post.
Kinda funny...Pitch loves them, and bbE hates them...you know me though, you'll get them and they'll be great, and i'll get them and they'll be $h!t...just my luck, eh?
Anyway, after looking at the new site, I noticed that you no longer carry (or show) the premium line of D/S rotors. What gives? What's the difference between the eLine and the Premium set? (i'll go back to the site and see if i can find out for myself).
Oh yeah, kudos on the new site...much better than the old one.
EDIT: I see that, among other things, the premium get more drilled holes and double-disc grinding.
Well, what's the price on the premium? I see the eLine going for under $200 on eBay.
