custom FWI for gxp
does that part from slp have the bung in it for the sensor? thats kinda why i didnt mess with that part, i didnt want to have to worry about drilling a hole in my pipe and attaching it.
as for water getting in.....its all closed off inside the fender, so it wouldnt pull in anymore than atmosphere moisture which the stock setup would be accountable for as well. what does the bypass valve you speak of look like/do in this situation?
Yes. SLP bellows includes sensor bung. Here's the link: http://www.slponline.com/view_product.asp?P=21042
It isn't going to necessarlity kill your intake but the most volume, at the highest velocity, is optimal. These car makers do everything in their power to make the engine as quiet as possible also, the accordian dampens the "whoop" sound when you have more air flow.
The funny thing is, any CAI or aftermarket induction piece I have installed on my rides or someone else's, the first comment everyone has is always about sound. People think it sounds BA when the engine starts sucking wind in the high RPMS.....who would have thunken to make it quieter?
...But i bet yours sounds nice.
the air does not stay stagnant in the pipe anywhere near long enough to heat it IF the pipe did get hot which it really doesnt. aluminum dissipates heat very well.
as for the water thing....the filter is in a closed fender on all sides, and it is as high as the headlight. If the engine portion of my car is headlight high in water--i have more serious problems than my intake.
as for gains, low end maybe slightly better, certainly no worse, high end gains are where i benefit. Sound is amazing--like a demon. its crappy out so i drive like a grandma mostly--fuel economy is slightly easier to achieve reasonable numbers, approximately 1 mpg improvement if im nice to the accelerator
the bypass valve negates any higher flow rates you might achieve with an intake.....there is only one hole where water could get in and i am scheming a solution to fix that.
i did lots of research on the topic of hydrolocking engines and the consensus was as long as you dont drive your car in unreasonable amounts of water you will be fine. trace amounts of water can go into your intake and they often do....aftermarket or otherwise.
I had a custom fenderwell intake on my 02 GTP. For the connections (bellows) I used a rubber sewer coupler from Home Depot and cut a small hole for the sensor. It never sucked up water but got real dirty. I would wash it in the spring and fall. Well worth $50 just for a KN filter and some PVC tubing.
yes please PM me what you used. Will do the same thing.
And about the sucking water in..where do people drive?? I had a CAI fender well intake on my 94 just like this close to the ground and never rode through water..
