Down pipe and u bend delete installed
Old Feb 8, 2008 | 07:31 PM
DavidGXP's Avatar
Default Down pipe and u bend delete installed
I had Curtis at Hogan send me a 3" down pipe and a 3" outlet a few months ago. Last week I finally found a guy who was willing to do the install for me and wow what a difference! No codes and no complaints.
Install: It took about an hour and a half and we used the stock cat. The rear outlet pipe from the stock cat was replaced with 3' of 3" pipe that was reduced down to 2 1/2 in order to fit the stock pipe just before the split. The rest of the system is stock, and will be replaced shortly. No resonator.
Sound: At idle the engine sounds a lot smoother. It's not as grumbley and at cruise the sound is very tame. I can tell by the sound, that the engine is not as taxed. Everything just sounds so mellow.
Performance: Total wow factor. Right off idle, theres still plenty of snap and tire chirp. Going into 1/2 throttle from a roll equals extreme acceleration. Go into full throttle and 0-60 seems to be in like 5.5 instead of 5.8. 2nd to 3rd pull is much more neck snapping and 3rd feels like 2nd.
I just ordered my PFYC carbon fiber hood and plan on having the rest of my exhaust system replaced with 2 1/2 pipe after the split (from 3"). Say good by to the stock mufflers. Way too restrictive! Oh and everything will be mandrel bent.
Old Feb 9, 2008 | 07:12 AM
SSWS6's Avatar
Sweet man sounds like its well worth it. The U-bend and downpipe are the most restrictive parts of the stock exhaust right? Or is it the rear manifold?
