what throttle bodies are the same as the LS4?
Old Feb 13, 2008 | 09:47 PM
Z28_DAD's Avatar
Default what throttle bodies are the same as the LS4?
a friend of mine wants a ported and polished t/b and i said i would do it for him. but the GXP is his daily hoopty and cant have the downtime for me to do the p&p. i looked on ebay under LS4, but no t/bs came up. any other ones that will work?
Old Feb 13, 2008 | 10:21 PM
TiredGXP's Avatar
I haven't come across one. (although my searching was mostly for an adapter from a 4 bolt throttle body to a three bolt intake flange)
My calipers tell me we have a 76mm TB, four bolt pattern. I believe the 5.3 truck engines have a 85mm TB, which won't match up too well to the intake.
Old Feb 14, 2008 | 09:09 AM
Area47's Avatar
COLORADO 04-05 Throttle Valve Assm; 3.5L
ENVOY 05 Throttle Valve Assm; 4.2L
TRAILBLAZER 03-05 Throttle Valve Assm; (4.2L)
HUMMER H3 06
BRAVADA 03-04 Throttle Valve Assm; (4.2L)
ENVOY XL 03-05 Throttle Valve Assm; 4.2L
ENVOY 03-04 Throttle Valve Assm; (4.2L)
IMPALA 06 Throttle Valve Assm; 5.3L
ISUZU ASCENDER 03-05 Throttle Valve Assm; 4.2L
GRAND PRIX 05-06 Throttle Valve Assm; 5.3L
ENVOY XUV 04-05 Throttle Valve Assm; 4.2L
TRAILBLAZER EXT 03-06 Throttle Valve Assm; 4.2L
CANYON 04-05 Throttle Valve Assm; 3.5L
MONTE CARLO 06 Throttle Valve Assm; 5.3L
TRAILBLAZER 06 Throttle Valve Assm; 4.2L
RAINIER 04-05 Throttle Valve Assm; 4.2L
SAAB 9-7X 05-06 6 cyl
Old Feb 14, 2008 | 12:02 PM
Z28_DAD's Avatar
wow, all those are the same as the 5.3s in the GXPs?
Old Feb 14, 2008 | 12:27 PM
Area47's Avatar
yulp
Old Feb 14, 2008 | 12:50 PM
Z28_DAD's Avatar
Originally Posted by Area47
yulp
nice. if i can aquire one, expect to see ported and polished t/bs for sale soon
Old Feb 14, 2008 | 01:50 PM
supercatxr7's Avatar
I'll take one if you do.
Old Feb 14, 2008 | 02:35 PM
Z28_DAD's Avatar
ill make a thread once i get some done
Old Feb 14, 2008 | 04:17 PM
You could do some type of core exchange. Send us one with a core charge, and then credit back once you receive core.
Old Feb 14, 2008 | 04:53 PM
Area47's Avatar
don't port them too much. they are super sensative
Old Feb 14, 2008 | 05:19 PM
Z28_DAD's Avatar
i plan on doing a core exchange.
ive done plenty of LS1 t/bs, so im not worried about going too far
Old Feb 14, 2008 | 07:00 PM
Mels SS's Avatar
Will the TB from the LS6 on the GTO bolt up and work?
Old Feb 14, 2008 | 07:08 PM
Z28_DAD's Avatar
aparently not. its not on "the list".
but ill take it
Old Feb 14, 2008 | 07:16 PM
TiredGXP's Avatar
IIRC, the GTO came with the LS1 with a cable operated three bolt TB or the LS2 with a 90mm electronic throttle body (4 bolt throttle body, but I believe the bolt spacing is different from the LS4 throttle body). I don't believe either will work.
Old Feb 14, 2008 | 08:11 PM
SILVER LS4's Avatar
I figure I will add this to the Throttle Body trilogy. The following was episode 2, titled "You Can Make the Shoe Fit, But You May Not Be Able To Wear It Because of Wiring Differences"
https://ls1tech.com/forums/ls4-performance/843096-different-tb-topic-revisited.html
Old Feb 15, 2008 | 09:03 AM
Area47's Avatar
don't "knife edge" the butterfly. this will cause severe idle issues. found this out the hard way.
