anyone elses car backfire?
Old Feb 15, 2008 | 10:46 AM
IMPALA SS 07's Avatar
Default anyone elses car backfire?
when im at WOT and my cars shifts from 1st to 2nd i usually let off the throttle then stomp back down on it and sometimes when i do that it backfires and makes a really loud pop and gets a good jump into 2nd gear...is this bad for the car and is anyone else getting this too?....o and btw im ordering a wet nitrous kit and running a 150 shot and am going to have it tuned and will be installed by spring
Old Feb 15, 2008 | 01:57 PM
BADDLS1SS's Avatar
may i ask WHY you stand on it till its in 2nd, let off then mat it again? Sounds like it hit the rev limiter though to me. Mine has done that before when trying to dial in shift points when it tinged off the revvy.
Old Feb 15, 2008 | 02:34 PM
kissmyss03's Avatar
lol why the hell do u let off and then pound down again. your causing your own issues
Old Feb 15, 2008 | 02:53 PM
MonteLover54's Avatar
If your going to do that you might as well drop it in to first and then shift when you feel the need...
Old Feb 15, 2008 | 04:18 PM
BADDLS1SS's Avatar
Or you could just leave it in 3rd or O/D And not have any issues.
Old Feb 15, 2008 | 05:12 PM
06MonteSS's Avatar
LS1Tech Sponsor
Nitrous??!! you can't drive it as it is!!
j/k man...
nope, no backfiring here...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Feb 15, 2008 | 06:13 PM
Count of Monte Carlo's Avatar
I used to do that in my '89 GP.....GM calibrated that trans to shift way too high at WOT so I'd quickly back off and get back on the throttle to induce an upshift...that was hydraulic governor controlled so it would lend it self to that but these full electronic ones, probably confuse it....
Old Feb 16, 2008 | 04:05 AM
Sint3k's Avatar
does not matter what you are doing it should not be back firing its bad for the intake manifold specially sense ours is plastic you make have a intake leak causing your **** to run lean
