Bent Suspention!
Old Apr 9, 2008 | 07:50 AM
Count of Monte Carlo's Avatar
Well I have this...
http://www.fquick.com/images/vehicle...jpg?1205600052
http://www.fquick.com/images/vehicle...jpg?1205600051
http://www.fquick.com/images/vehicle...jpg?1205600388
They aren't dead on....Unless somone has a better shot....
Old Apr 9, 2008 | 04:36 PM
Sint3k's Avatar
Dealership said they can't warranty it , they said GM wil want the part back and they will end up being charged once they see it was due to road conditions so i'm just going to order 1 BMR lateral arm and replace em as they bend lol
Old Apr 9, 2008 | 06:23 PM
BuffaloSS's Avatar
IDK that you can replace just one or the other. WOuldn't that cause handling irregularities?
Old Apr 9, 2008 | 09:11 PM
Sint3k's Avatar
No these parts only move in one direction as long as i have a alignment done after also this oem one is bent to **** and i don't notice anything. Besides the OEM one is 100 bucks cheaper and i think i might just replace it with OEM cause i doubt this will happen again.
Old Apr 9, 2008 | 10:00 PM
Sint3k's Avatar
Has anyone ever ordered from gmpartsdirect.com ? they have the rod i need for bout 30 bucks cheaper. If you have ordered does it take them long to ship ? thx.
Old Apr 10, 2008 | 08:23 AM
BuffaloSS's Avatar
Yes, it takes them FOREVER to ship...almost 3 weeks on the STB's I ordered and a month on the TPMS sensors. If you become an active member at NAIOA, ZSPOT might be able to cut you a break on the part.
Or you can sign up at ClubGP and order from Monster Parts.
However, I can't imagine there's not a GM supporting vendor here to order from...so check it out. (Maybe www.SDPC2000.com or http://www.gmperformancepartszone.com/)
Old Aug 5, 2008 | 08:10 PM
06MonteSS's Avatar
LS1Tech Sponsor
Originally Posted by Sint3k
I was working on my exhaust cutout because it had seized up from rust while iw as under the car i got to noticing one of the control arms "i think thats what its called" was bent probably from a hitting the dear a few months ago! I looked on the other side and its bent to accept the one towards the rear of the car accept the one towards the front. Hopefully my warranty will cover this!
yeah, reviving an old thread here...
how the hell did that get bent??
I've just got done hitting some BAD potholes and "speed bumps" on the highway doin 50-60mph, and just checked my **** out... everything is still fine and straight...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Aug 5, 2008 | 09:20 PM
06MonteSS's Avatar
LS1Tech Sponsor
aaah, ok... that makes me feel better... heh..
yeah, cuz they're doing work on the highways around here... grinding it down and re-paving.... well, eastbound, the ridge between the grinding and the old road, they didn't smooth out the transition so well, and it's a friggin speed bump, and I mean HARD....
thought my front/rear end was gonna fall off...
but after looking at everything from underneath tonight, everything is still straight and tight...
whew!!!
nothing like what the pictures show in this thread...
heh...
__________________
Old Aug 5, 2008 | 10:10 PM
06MonteSS's Avatar
LS1Tech Sponsor
yeah, searched before and found that pic too... ny **** DEFINITELY doesn't look like that...
don't even have the small curve/bend that the OP has...
so I'm good...
whew!!
hehe
__________________
Old Aug 6, 2008 | 01:38 AM
Sint3k's Avatar
so I'm good...
whew!!
hehe
I think it was from doing several 360's after clipping a deer. I actually havn't replaced it yet i will be buying the part tomorrow odd timing. I just bought the haynes manual to make sure there wasn't anything special i needed to do to remove it. They do recommend you drop the crossmember on the side your replacing and leave the other side bolted up. I don't really know a safe place to put the jack to hold the rear up besides on the suspention. There are the pinch weld spots where the unibody is for the OEM jack but i'm afraid i'll bend the metal if i put my jack there. Maybe i can get a adapter for the jack that will fit.
Old Aug 6, 2008 | 11:59 PM
Kazmaniac's Avatar
I use the square tube part of the uni where the rear clip meets the body. Theres a spot right before the rear and just behind the fronts. Standard jack pad grabs it ok.
No issues in several cars.
