camshaft
Old Apr 13, 2008 | 10:13 AM
CardinalsRed's Avatar
Default camshaft
what performance cams would be a good upgrade for my car?
with: K&N intake, corsa mufflers, Jet mass air flor sensor
Old Apr 13, 2008 | 12:12 PM
Nacho SS's Avatar
LS6 cam.
Old Apr 13, 2008 | 06:25 PM
ls6? hmm... thanks. do you have any recommendations, brands or sizes?
Old Apr 15, 2008 | 07:53 AM
Brian396's Avatar
Trick Flow Track Max Camshafts for GM LSX
TFS-30602001
TFS-30602002
TFS-30602003
Old Apr 15, 2008 | 08:03 AM
Mels SS's Avatar
Is it a direct replacment?
Old Apr 15, 2008 | 09:41 AM
EmersonHart13's Avatar
What about the LS2?
Old Apr 15, 2008 | 04:24 PM
Brian396's Avatar
No different bolt pattern but they make an adapter, I’ll be dammed if I can find it right now.
Old Apr 15, 2008 | 07:03 PM
JPH's Avatar
JPH
use '06 LS7 timing chain set. if were talking about 5.3 ls1 fwd cars.
Old Apr 15, 2008 | 08:07 PM
someday's Avatar
how about a TR220... remember that this is a 5.3 liter, not a 5.7 or 6.0...
Old Apr 25, 2008 | 03:08 PM
i read that the engine block is one inch shorter. does that matter? will any ls6 cam stil work?
Old Apr 25, 2008 | 03:11 PM
Taz34SS's Avatar
You will have to disable the DOD for the cam to work, along with I believe removing some parts from the engine.
Old Apr 25, 2008 | 06:33 PM
TiredGXP's Avatar
The block is not shorter. The crank has a shorter snout and flexplate mount, and the accessories, especially the water pump, are arranged in a more compact way. Overall the "engine" is shorter.
Bore spacing, therefore main journal and cam journal spacing is the same as the other GEN 3 and Gen 4 blocks. A LS6 cam will fit.
Old Apr 25, 2008 | 08:37 PM
Nacho SS's Avatar
What he said....LS6 cam like I said earlier...
Old May 1, 2008 | 05:41 PM
sounds good .. would disabling the DOD make that big of a difference in fuel mileage? most v8 camaros get about the same mileage as we do and they run on 8 cylinders all the time.
Old May 1, 2008 | 07:41 PM
TiredGXP's Avatar
Fuel economy on the highway will drop about 10% (if you drive 80 and up, chances are DOD is rarely active due to wind resistance, so you may not notice much change). Losing DOD in the city will barely be noticeable since DOD is not active at low speed, when idling or accelerating.
If I ever do a cam in a LS4 (maybe on the next Fiero), I'd probably dust all the DOD hardware and put in a LS1 valley cover, just to make an intake swap less of a pain.
Old May 2, 2008 | 07:37 AM
SSWS6's Avatar
Damn this is what, maybe the 1000th post about cam swaps. I wonder if anyone is actually ever gonna tackle this project! I bet when people start to realize the amount of labor involved they change their mind. I hope someone does it though, I would love to see the results. Not something I plan on doing to my car though. Too much work for too little gain. Plus my tranny and tires already can't handle the power of my stock LS4.
Old May 2, 2008 | 04:59 PM
i'm going to add a cam.. just going to wait for my warranty to end. so probably won't be until january of 09
Old May 2, 2008 | 05:24 PM
Area47's Avatar
::slams head into desk::
