Beef up the transmission
I think the transmission is one of the weakest links in this car and I would think it's the best place to make improvements before putting any more than basic bolt on hp.
I don't mind more expensive suggestions too (I have a feeling they're all pretty costly)...I'm mostly looking for a list of things I can do and how much each would cost (parts/est labor).
Aside from transmission strengthening, I'm also curious to know how much it would cost if I decided to go with 3.29 or 3.69 gearing.
Lets get a good discussion going! It's been a while!
And if any gear heads (pun intended) could draft up a shopping list of what to get and why would be awesome...and a good thread for the board.
The cooler: http://www.bulkpart.com/Merchant2/me...roduct_Count=3
More Instructions: http://tacgp.clubgp.com/custom_mods/...ler/index.html
And Even MORE instructions: http://www.geocities.com/fastxtc/gp/auxcooler/
www.tripleedgeperformance.com
Also good info here to take a look at and search in:
http://www.grandprixforums.net/f21/
This is what is going in mine.
PATC 2800 Stall Torque Converter - 399.00 (Ordered 2/24/2009)
ZZPerformance Input Shaft - 359.95 (Ordered 2/24/2009)
TEP Clutch Master Rebuild Kit - 159.95 (Ordered 2/25/09)
TEP Recond. Input Clutch Piston - 19.95 (Ordered 2/25/09)
TEP Input to Sun Gear Bearing - 6.95 (Ordered 2/25/09)
TEP 4t65e Lube Dam - 3.95 (Ordered 2/25/09)
TEP OE Stator Support / Drive Sprocket Bearing - 7.95 (Ordered 2/25/09)
TEP Transgo 4t65e Shift Kit - 59.95 (Ordered 2/25/09)
TEP Channel Plate for GXP/CompG - 7.00 (Ordered 2/25/09)
Intense 3.29 - 15/16th’s Gear Ratio Conversion Kit & VSS 3.29 Reluctor Wheel - 450.00 (Ordered 2/24/2009)
This setup should be great for the car. It has been awhile since the car was itself; a little over a year since the trans. went bad.
-Mike
