Weird rattle when 8>4 cyl. switch...maybe tranny?
#81
One thing I've noticed with DOD, when I had my shift pressure raised with HPTuners, the change from 8-4 or vice versa is very abrupt, it was never like that before I had the shift points messed with. Has anyone else noticed this?
#82
Did they say why GM designed it to start making the noise after 22k miles?? Perfectly quiet before that, then after 22k miles it started getting louder and stayed there. I wonder if they have a random number generator in their design software to make this start happening and mine was set at that mileage...
#84
As far as I know the noise goes away when it warms up so that's fine by me. If the lifters want to clatter when its cold then let them. Lifters do that at times.
#85
Right on - I'm with you on this. After paying close attention over the last few weeks, mine also only makes the noise when the oil is not completely up to temp. After the oil warms up, no noise.
#86
Mine does this all the time, cold or not. I got home from my vacation...after driving some 400mi from the mountains...and when I got back on city streets, it went right back to makin noise. I threw a p0054 code for an issue with the rear o2 sensor, so I'll be taking it to the dealer in the near future for that, and will ask them to investigate the lifter issue (again) as well.
#87
Its not completely gone but its so minute that i have to strain to hear it. Well if they can classify it as a problem for you best of luck. BTW I had a misfire code and basck when I had the 3 inch DP on I had a lean code...I think my o 2s are foulded up but they want me to remove the K and N, so I did. We'll see if it tosses th ecode again. Naturally Idon't belive that the K and N has anything to do with it, but i'll play along
#92
so is anyone suggesting this could be normal? because anything that sounds like what we are hearing is not normal. and im not going to drive around in a beautiful car that sounds like its falling apart.
#94
There is a difference between "normal" and "common." While the sound is apparently "common," it's definitely not "normal."
I would not allow the dealer to brush it off as "normal." I would ask not only the tech to get in the car to hear it, but that the regional rep join you and see if they would like to drive around with a relatively new car sounding like that.
I completely understand what is causing it...but it's not acceptable. Apparently, GM never tested a DoD/AFM engine long enough to allow it to get to this point.
#96
Pretty sure Count described what is happening earlier in this thread, and in another thread posted just a couple days ago.
Regarding TSB's...I guess enough of us haven't complained yet. Let's all start calling the GM complaint line and see where that takes us
#98
what exactly is the difference between a DOD lifter and regular lifter? if the lifter is collapsing what does that mean? also if i disable the DOD will it harm anything in the long run?
#99
#100
