getting inspected, will hp tuners screw anything up?
Old 05-10-2008 | 02:28 PM
deft's Avatar
Default getting inspected, will hp tuners screw anything up?
so i installed a hogan hi-flow downpipe and cat......i got the catalyst system low efficiency code for the oxygen sensor so i just went into hp tuners and uncheck ses enable in the dtc menu. as far as i know this wont enable my car to go into speed density mode? will this cause any problems getting inspected? im not certain what they do when they inspect a car, but im hoping this wont throw any flags up.
Old 05-10-2008 | 03:08 PM
CardinalsRed's Avatar
ya you better reset it to stock. tuner can void warranty. but all you have to do is flash it to stock and after it passes inspection, re-tune it back to how you have it
Old 05-10-2008 | 03:44 PM
Taz34SS's Avatar
There are laws to prevent a dealer from voiding a warranty.
You will be fine, just turn off all the Bank 1 Sensor 2 codes and you will be fine. I Can also give you the list to turn off if needed.
Old 05-10-2008 | 03:54 PM
deft's Avatar
if i do that, it will throw a code--im not concerned about warranty, i just want my inspection sticker.
so taz, they typically dont browse your pcm when they do an inspection? i just turned off the one code and its been fine for about a week. it seemed to throw the code when the temperatures dipped down into the 40s here last week.
Old 05-10-2008 | 06:35 PM
Taz34SS's Avatar
Here, turn these off and make all of them no longer able to report to the ECM
P0036
P0136
P0137
P0138
P0140
P0420
P0421
Old 05-11-2008 | 12:45 PM
20SS07's Avatar
As far as inspection goes you should be fine. They're mainly looking at things like, brakes, tires, lights, etc. Anything that would be a safety concern or make the car not legal to be driven on the street. Stuff like not having a cat too.
Old 05-11-2008 | 01:09 PM
Nacho SS's Avatar
P0036
P0136
P0137
P0138
P0140
P0420
P0421
I was just going to post those.
Old 05-11-2008 | 01:22 PM
Taz34SS's Avatar
Now only if DS could offer that kind of fast support for people
