replacement battery size?
Old Jun 26, 2008 | 06:37 PM
06 SS's Avatar
Default replacement battery size?
Well, GM's finest-available-for-the-price battery took a dump on me today. Put a meter on it and I lost a cell for sure. As it is a whopping 3K miles out of warranty, am just going to go get an Optima and, from glancing at it, be swearing up a storm when I replace it tomorrow. Anyone know the case size and any tricks for swapping that bad-boy outta there?
Old Jun 26, 2008 | 08:00 PM
neilownz's Avatar
Used search function and got #35 red top but someone has a #36 and it was difficult for them to install. So either might be possible...
Old Jun 26, 2008 | 08:06 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I have the older/larger one, and it used to interfere with my a/c line until I rerouted it...they should know which one..when I got mine about 4 years ago,there was 1 size.
Old Jun 26, 2008 | 08:35 PM
06 SS's Avatar
I searched as well, it is the 35, was mostly looking for hints at the process, I usually figure out the right way to do it about the time I finish the job. On the minus side, nobody in the known universe carries the 35. They can order it, yes sir! But to actually have a battery on the shelf? That's crazy talk!
Nobody ever has to replace a battery after it fails, they just should know it is going belly up 3 days before it does.
Old Jun 26, 2008 | 08:38 PM
Nacho SS's Avatar
ain' that life?
Old Jun 26, 2008 | 10:09 PM
mike690003's Avatar
I have the Optima red top 36. Save yourself a lot of frustration: Order the #35 and slide it in. The #36 will really test your patience, Its a royal pain to install!
Old Jun 26, 2008 | 11:55 PM
06WHITEMCSS's Avatar
Plus if you order the 35 you should get the freshest battery available, not one thats been on the shelf for a year.
Old Jun 27, 2008 | 12:05 AM
neilownz's Avatar
If you can go without one until they get it in.
Old Jun 27, 2008 | 12:17 AM
Nacho SS's Avatar
^Which is usually never the case.
Old Jun 27, 2008 | 12:23 AM
Thats worse case scenario.
Old Jun 27, 2008 | 06:26 AM
06 SS's Avatar
I will search around for one today. Problem is that I am just home for the weekend, then back to Indy for another couple months (so ordering it here would do no good). I had a load on the battery (flashing light and radio for much of the day, same as the 6 weeks before) before the cell quit on me. I am a bit too familiar with batteries for my own good. I know just about exactly what they will take before they fail and, while I could reasonably safely baby it for a week or so, it could still quit in an instant. The cell could be opening slowly or quickly, just no rhyme nor reason to it. Bottom line is that I don't trust it.
Old Jun 27, 2008 | 06:40 AM
05CherryGXP's Avatar
Nah, it just means it sat on the shelf at some warehouse for a year, rather than the shelf at some parts store.
