Transmission question
Old Sep 21, 2008 | 05:01 PM
okie123's Avatar
Default Transmission question
Well...I almost hate to ask but I'm going to.
I think I already know the answer but here goes.
Only mod drop in K&N. Not over oiled and MAF cleaned with MAF cleaner about every 15k. Car has 75k on it. Car has maybe 10 passes at the track at a much earlier life. Babied and maintained very well otherwise. Transmission has been flushed three times so far. Second flush the transmission was overfilled about a quart. No big deal except while going up into mountains. Too much fluid cavitated the pump, strange sound and with air being drawn temps went up to 235F. Stopped at a dealer in New Mexico when it happened and they dropped pan for inspection, flushed and sent me on my way. All looked good and sounded good for about 3 months. Now....
Cold start up. Put into drive. Perhaps the second or third stop light about
1 out of 15 trips. Not predictable. Light acceration within first 30', car rpm comes up, and seems to jerk or lurch forward. this will only happen when car is cold. Shifts perfectly at all other times. Only from take off when cold.
I plan on taking it somewhere for an inspection. Aamco probably. if it is what I think, punt and sale the car. There has been soooo many transmission problems with these vehicles, is there any chance at all that I'm not looking at a new transmission? Thanks for any thoughts.
Old Sep 21, 2008 | 05:20 PM
StealthV8's Avatar
235F isn't that high. I have 50000 miles and have hit that temp lots of times. Last time i hit that temp i did a huge burnout after and the temp went to 250f lol. Doesn't sound good for you though. I don't think the trans problems are as bad as they seem its just that everyone posts about their transmission problems. I'm not easy on my trans, its never been flushed, never changed the fluid yet and she still works perfect.
Old Sep 21, 2008 | 06:01 PM
98Jeep360Limited's Avatar
I've had my share of tranny problems, but haven't had this happen yet. I'm not a trans expert by any means, but based on what you say its doing, almost sounds like a valvebody issue.
Old Sep 21, 2008 | 06:40 PM
05CherryGXP's Avatar
Sounds like the trannie man. I had roughly the same thing happen to me with the little jerk on shift. For me it as coming out of my driveway and hit the gas. It did it off and on for maybe 6 weeks, I had my dealer look at it but he couldn't find ****. Then one day second gear just plain died on me. Kind of funny actually, I was pulling out onto a street, big Mac truck coming up and the car suddenly just redlined, no power to the wheels. I had to jam it into tapshift mode and punch it up to 3 to get power to the wheels. Good thing I make enough power to move quickly when I need to.
The current theory (I stress the word theory) that we worked out in my class is that the heat is stretching the chain in the trans. The way our exhausts run they bend right around the trannie, which may be the source of heat. A guy who has pulled apart a few blown up GXP trannies says the chain was stretched on all of them and metal fragments were coming off it. As a bandaid we've tried heat shielding around that section of the exhaust near the trans and an aftermarket trans cooler.
I'd take the car in now, drop the pan and look for metal shavings that show the chain is going. I assume you're long out of warranty so you're screwed. I hear Milzy Motorspots in Ohio is looking for a W body to put a M6 in as a test, you could always have that done!
Old Sep 21, 2008 | 07:48 PM
06WHITEMCSS's Avatar
Sounds like it could be a torque converter issue.
Old Sep 21, 2008 | 08:02 PM
okie123's Avatar
Thanks for all your input. I suppose I should take one step at a time. If I have any time
at all tomorrow, I'm going to have them pull the pan and look myself as the pan is dropped. Not that I dont trust anyone but........I just have not decided who.
Old Sep 22, 2008 | 07:46 PM
okie123's Avatar
I watched them drop the pan today and nothing abnormal was found at all. The filter
was changed for the first time today as previous services just flushed. I went back with their synthetic blend. As infrequent as this occurs the tech suggested I change out a thirty dollar electronic coolant sensor and check the wires well. If it does it again I'll follow his lead and clean the maf sensor again. It seems I've read somewhere that if oil gets on the maf sensor it may cause driveability issues. Thats about it. For a true litmus test I'm tempted to take her to the strip for about 6-7 passes. The car has been babied too long.
Old Sep 22, 2008 | 09:31 PM
Sint3k's Avatar
Its only a few G's for a new rebuilt transmission that can be built better and last longer then the stock one and you'll never have to worry about it. As for flushing every 25k sounds like a waste time and to the comment "suppose to" its recommended flush is 100k in my manul.
