Trans cooler/fan, TCI flex plate, super servos, temp gauge
Doing a t56 swap...so the auto is going. Here is what I got...
Trans cooler 8x11 with mounted fan $130 shipped brand new never installed (SOLD)
TCI Flex plate HD LS1 #399753 $160 shipped with crank bolts
Super servos 2&4 with 20 miles on them, $130 shipped (180 new)
Very easy to install and a must for any bolt on or h/c car. With simple inst.
they maintain the Largest apply area available for 700-R4. 35 percent more apply area than the Corvette servo.
Super positive 1-2 shift.
Quicker servo release on the 4-3 downshift.
Positive 3-2 kick down.
Adjustable pin tip included to set perfect band clearance.
Great for heavy service, towing, racing and off-road.
Also can be installed on the 4L60-E.
Kit contains two-piece 6061-T6 billet aluminum piston set with three piece steel washer
set, servo clip, servo pin extender, custom return spring and four piece Teflon sealing
ring and O-ring set.
THIS IS A UPDATED NEW SERVO KIT AND HAS THESE FEATURES;
SUPER POSITIVE 1-2 SHIFT.
IMPROVED 2-3 SHIFT.
QUICKER SERVO RELEASE ON THE 4-3 DOWNSHIFT.
POSITIVE 3-2 KICKDOWN.
ADJUSTABLE PIN TIP INCLUDED TO SET PERFECT BAND CLEARANCE.
35% MORE APPLY SURFACE AREA THAN THE CORVETTE SERVO.
Note thats only for the 2nd piston and I have the 4th piston too.
Autometer Trans temp gauge $40 shipped. Never installed (SOLD)
MAF with screen $50 shipped.
Auto pedals $55 shipped.
auto shifter/cable $55 shipped.
Nice auto console $60 shipped. pic below...(SOLD)
I also have my fuddle STR2.1 3200 tight stall, new 20 miles. $240 shipped (SOLD)
Add the 3% to paypal.
Pls don't low bal. I will ship quick and send track # via UPS.
IMPROVED 2-3 SHIFT.
All you need is a presure hose, like a fuel injection hose. On the low pressure line since I got the barb fitting a hose clamp will hold it. I set it up for putting it under the right side under the bat area. You can mount it anywhere. Its ready to bolt up...
