Diamond custom pistons, NIB and Nitrous fuel system, nossle kit
boost pistons, high comp pistons, 105mm and t67mm turbos, 160 lb injectors
NIB Diamond pistons 3.910 bore, setup to handle a 350 direct port nitrous system, 12.5:1 comp, big wrist pins and ring set. can also be flat topped by any machine shop for a lower compression. 600.00
NIB Wiseco K392A07 dished 3.905 bore pistons and rings, perfect for boosted build. 600.00
105mm Innovative turbo, fresh center section, 1200 HP to wheels.
It is a 105mm Innovative turbo with a T6 turbine inlet, I believe it was a 1.3x turbine a/r, 4" o-ring v band compressor cover, 5" v-band downpipe. This turbo made 1200 to the tire on my friends mustang and went 7.9x at 17x. No shaft play or leakage, Has 2 passes on it after Innovative replaced the CHRA. I was going to use it on my 408 but funds have run out on the project. 1800.00
New Garrett T67 with S cover 4" inlet 2.5" outlet, T4 turbine, on center,.96 a/r 3" v-band downpipe, good for 600-700 to tire 800.00
New Bosh 160 lb low impedance injectors-SOLD
105mm on the left T67mm on right in pic.
All part are plus shipping and obo
Do you have pics of the fuel cell and pump set-up? Where does it mount to? Pics to jparks@cinci.rr.com
Thx Jer, you got me all fired up and building the turbo kit as i type this!! I think it will sell very well once its all finished, its comming out pretty nice.
Here are some pics of the fuel system. I do not remember the brand of the tank but it is aluminum with -AN fittings and a rollover vent. The fuel lines are black push lock. If i remember right the lines are -8 feed and return. The -an ends are silver and the regulator is a Mallory 4309. THe system comes with pump, filter, tank, feed and return lines and regulator.
Both sets of pistons are set up for a 6.125 rod.
