Motor mounts.
Old Oct 15, 2008 | 12:07 PM
ladybird's Avatar
Cool Motor mounts.
I need either prothene of solid motor mounts for my 96 LT1. The factory rubber has already worn out after less than 2 years. I need something a bit tougher. Ok, alot tougher.
Old Oct 15, 2008 | 12:27 PM
EliteCamaro94's Avatar
me too where's a good place to get them
Old Oct 15, 2008 | 12:36 PM
Elliott's94Z's Avatar
My car shakes a lot more and has a few more rattles with the polly mounts. My factory ones were shot as well.
Old Oct 15, 2008 | 01:07 PM
Jditlfm's Avatar
You can buy them at autozone part numbers 3.1116G and 3.1127G For black mounts or 3.1116R and 3.1127R for red mounts. You can also get them off summit. I have the Energy Suspension performance polyurethane motor mounts and i dont notice any harshness. I like them and the fact that they wont break. This thread will show you how to install them http://www.camaroz28.com/forums/show...e+mount&page=2
What i did because my dad is a welder is clamped them together and had him weld them together all the way around. I dont think they will ever come apart.
Old Oct 15, 2008 | 01:28 PM
connexion2005's Avatar
I'm running ES Poly Motor Mounts with a factory rubber trans mount and it is very very smooth with no shifter slop. I have a 383 w/ the cc306 and at 800rpm idle there is no shaking and the motor stays completely still at a choppy idle. You won't be disappointed in their product. I also ran them on my Ls1 with a 110lsa cam and they held up very well.
Old Oct 15, 2008 | 01:29 PM
Jditlfm's Avatar
i also have the poly trans mount from them i forgot about it cause i put it on so long ago.
Old Oct 15, 2008 | 04:02 PM
ladybird's Avatar
Cool
I have a M6. anyone know the part number for the poly transmission mount?
Old Oct 15, 2008 | 05:20 PM
leadfoot4's Avatar
I have both the ES motor mounts, as well as their tranny mount. Did the "mod" to the tranny mount, and I have no complaints....
Old Oct 15, 2008 | 09:53 PM
ladybird's Avatar
Cool
Leadfoot4 what is this mod that you speak of.
Old Oct 15, 2008 | 10:14 PM
HoLLo's Avatar
I think this is the weak link in my shaky idle -- bad motor mounts. I've got the Prothane transmission mount, and have a torque arm mount, swaybar endlinks, and bushings on the way. Sounds like its time for some motor mounts too.
You can't go wrong with either Prothane or Energy Suspension
Old Oct 15, 2008 | 10:19 PM
RedRyder518's Avatar
I have ES poly motor and trans mounts....absolutely no complaints with them. They are a little rougher, yes..but they will last. They did soften up a tiny bit after wearing some.
Old Oct 15, 2008 | 10:58 PM
hyperzone's Avatar
Thunder Racing Has poly mounts. About $29 for the tranny mount, and $59 for the motor mounts right now as I'm posting this. I have these and have more vibrations now than compared to stock. Nothing ridiculous but, it is noticable.
Old Oct 15, 2008 | 11:07 PM
camar0corey's Avatar
Summit has the Prothane kit for $70 or around there(I just got mine two weeks ago you'd think I could remember). Anyways it has the motor mounts and the trans. mount.
Old Oct 15, 2008 | 11:45 PM
96blackz28's Avatar
good info guys, i got the poly trans/motor mounts off thunderracing 2 weeks ago bout to put them in... my stock ones were junk, i hope these work well enough, but i wont know a good diff since my original oneswere junk when i got the car
Old Oct 16, 2008 | 11:37 AM
leadfoot4's Avatar
You do not use the "preload plate" that ES includes, and you also grind down the two "nubs" that are part of the polyurethane.
Old Oct 16, 2008 | 11:45 AM
riceburnerZ28's Avatar
I got the prothane motor/trans mounts.... no complaints here !
Old Oct 16, 2008 | 12:46 PM
so i have the stock rubber tranny mount on my car which i have broken 3-4 times but i think im gonna stick with it cause i dont want the vibrations. But from what everyone is saying the prothane motor mounts are good or energy stuff is good correct? will i get vibrations from having those motor mounts?
Old Oct 16, 2008 | 01:29 PM
koolaid_kid's Avatar
I am in the process of installing the Prothane Motion Control set I got from Summit. They had all three in a set. All I have to say is you had better have a powerful drill and sharp, quality bit to drill out those $*&(*&^ rivets. What a PITA.
As a side note, I have read in other threads that if you want the transmission part, you had better do the motor mounts as well. Something about the vibrations being different between the two causing problems if you only do the tranny mount. Only what I read, not from personal experience.
Old Oct 16, 2008 | 07:05 PM
LS1 Eddie's Avatar
Madman makes solid motor mounts for the LT1. Anyone using them? Or have any experience with solid motor mounts in general?
Old Oct 16, 2008 | 07:49 PM
Schweet97Z's Avatar
Im going to be running Solid mounts on the new car...ill let you know how I make out.
