What is this?!?!?!
Old Oct 16, 2008 | 01:08 AM
nik1703's Avatar
Default What is this?!?!?!
I found this hanging loose in my engine not connected to anything. what is it???
(93 firebird LT1)
Old Oct 16, 2008 | 01:19 AM
hyperzone's Avatar
Maybe for the hood latch release. Looks like a throttle cable or e-brake cable adapter of some sort..
Old Oct 16, 2008 | 01:31 AM
nik1703's Avatar
car has an edelbrock 52mm throttle body installed by the previous owner, think that has anything to do with it?
Old Oct 16, 2008 | 01:33 AM
riceburnerZ28's Avatar
that look like the ebrake cable
Old Oct 16, 2008 | 01:39 AM
nik1703's Avatar
the Ebrake works though?
Old Oct 16, 2008 | 01:42 AM
did u trace the wire back to its source ?
Old Oct 16, 2008 | 01:43 AM
nik1703's Avatar
did u trace the wire bace to its source ?
It's got a long black cable connecting to it, that connects it to this harness-like thing on the right side of the engine compartment.
Old Oct 16, 2008 | 01:47 AM
there should be 3 of those wires 2 goes to the throttle body and the other goes to the hood latch ! I was just under my car and I'd swear i saw something like that bolted under the car near the center !
Old Oct 16, 2008 | 01:54 AM
nik1703's Avatar
Yeah man, i'm not entirely sure. I'm thinking its the TB cable from the original TB. I'll take some better pictures tomorrow. I also found an aftermarket alarm installed on there while I was snooping around. It's not active, which is why my clicker isn't working.
Old Oct 16, 2008 | 07:45 AM
Paul Bell's Avatar
That's MISTER MODERATOR
WTF GUYS! Man, I’m feeling old!
This is a hood lock cable from Wolo. It mounts on the radiator support and the sliding pin would go through a hole in a bracket bolted to the hood. On the other end of the cable, there’s a circular key cylinder that slides the cable. Also in the key end was a pair of wires on contacts that was an ignition kill. First made in 1965.
Old Oct 16, 2008 | 01:35 PM
nik1703's Avatar
Thanks for the info! Sounds like you know your stuff.
The car does have an aftermarket hood, so that would probably explain it. It's a suncoast ram air hood. What are your thoughts on that hood you guys?
Old Oct 16, 2008 | 02:42 PM
PNYKLR-TA's Avatar
hook looks decent, im more a fan of the WS6 hood for LT1 TA's but then again you dont want to be making a clone or anything god forbid you did that you might get shot by someone who paid soo much for their real WS6.
Old Oct 16, 2008 | 03:29 PM
jarretthise's Avatar
haha i figured it was a hood latch but i wasnt sure! that hood is nice...i like it!
Old Oct 16, 2008 | 09:39 PM
Paul Bell's Avatar
