Oil Pan Access?
Old Oct 17, 2008 | 11:55 AM
93Z2871805's Avatar
Veteran: Air Force
Default Oil Pan Access?
I kind of have a somewhat stupid question, how exactly do you remove the oil pan with out dropping the k-member? I was wondering because, when I put the studs into the mains and change the oil pump, I'm going to move the k-member. But, how do you lower the k-member to work on the bottom end hence your motor mounts are on the k-member, or do I have to lower the whole front clip and put the motor on a stand? WTF? Can someone explain this?
Old Oct 17, 2008 | 12:30 PM
fergymoto's Avatar
It's easy. All you have to do is take out the two motor mount bolts and jack the engine up until the oil pan will come out. I can have an oil pan out in 20 minutes including jacking the car up.
Also, make sure you take the low oil level sensor out before you drop the pan. It will get hung up on the windage tray.
And last, I wouldn't recommend putting in main studs without being able to check the main journals for distortion. You can't really do that without the motor torn down on the stand.
Old Oct 17, 2008 | 12:31 PM
1redta's Avatar
Default re
you do not have to drop the k-member to pull the stock pan. the difficulty depends on whick trans you have I think the M6 is tougher. When I pulled the stock pan for a Canton I supported the motor with a cherry picker and then losened the k-memeber bolts one at a time. I did this so that I could leave the k-member hanging on the last 3-4 threads of each bolt. Came out pretty easy over all
Old Oct 17, 2008 | 12:42 PM
Jditlfm's Avatar
You can not get the pan off the engine in a m6 without lowering the k member or removing the trans, I have done it. I jacked the engine up with the motor mount disconnected and lowered the k member that was the only way the pan would clear the trans while pulling it out.
Old Oct 17, 2008 | 01:53 PM
93Z2871805's Avatar
Veteran: Air Force
I have an A4, so from what I'm getting I can just jack the motor up after I loosen the motor mount bolts. I didn't know if you could do that because of how far the cowl is over the engine. Fergy you really think the mains can be distorted to where I won't be able to get studs in? That means if they are, an align hone is in my future huh?
Old Oct 17, 2008 | 02:03 PM
the_merv's Avatar
I wouldn't do anything to the Mains unless you had the Engine tore down.
Old Oct 17, 2008 | 02:14 PM
93Z2871805's Avatar
Veteran: Air Force
Would it still be safe for me to do the main bearings, rod bearings, oil pump and new ARP rod bolts?
Old Oct 17, 2008 | 02:35 PM
the_merv's Avatar
That can be done, but it will be a pain in the *** with the K-member there. I'd be less work to pull the Engine.
Personally, if I''m changing Bearings, I would get the Crank Journals polished. That way they are cleaned up for the new Bearings. You never put an old surface on a new Bearing.
Old Oct 17, 2008 | 02:49 PM
93Z2871805's Avatar
Veteran: Air Force
Here's my dilemma, I wanted to beef up the bottom end a LITTLE bit but, I need my car to get back and forth to base and I don't have another ride. And to top it all off, this is all before I get the 383 together so the motor in the car wont stay. When the 383 gets thrown in the original 350 is gonna become another spare 355 or 383.
Old Oct 17, 2008 | 02:52 PM
the_merv's Avatar
So why put stuff into it when it's just going to sit out as a spare..do it when you have it out and need it..
Old Oct 17, 2008 | 03:01 PM
93Z2871805's Avatar
Veteran: Air Force
I'm a little worried about blowing the 180,000 mile motor in the time being, and then I'm hosed! I just don't know if I trust a stock cast botom end motor with that many miles on it.
Old Oct 17, 2008 | 03:27 PM
the_merv's Avatar
I've seen them go with more.. don't romp on it too hard if you are worried about it.
Old Oct 17, 2008 | 03:48 PM
chavez885's Avatar
180k miles isn't bad. Just don't drive like a jackass, put a good oil pump in it and keep plenty of good oil in her.
Old Oct 17, 2008 | 04:21 PM
fergymoto's Avatar
It's not that they are already distorted, it's that sometimes they become distorted after adding harder clamping fasteners. When that is the case the mains need to be align honed.
If I were you I would leave it alone unless you think you have lower than acceptable oil pressure. If that's the case then you could try a higher volume oil pump to bandaid it till the new motor is ready.
Old Oct 17, 2008 | 07:24 PM
93Z2871805's Avatar
Veteran: Air Force
I've been babying the **** out of it for awhile. It's getting old.
