Please double check my troubleshooting skills
Old Oct 18, 2008 | 08:37 PM
1995Transamconvert's Avatar
Question Please double check my troubleshooting skills
I read and read on this optispark thing. Please tell me if you think I'm right. It's a 1995 Trans Am 5.7. Driving this morning and it starts, spitting and sputtering, black smoke, missing,...you get the point. It had run flawlessly up to this point. Check engine light comes on and that's it. It won't restart. Had it towed home and starting trying to read any codes in the computer. It shot out 42, then tons more...16,18,36...
So on a whim I buy a NEW ICM and coil and swap them out. No effect. New TPS and Air Charge Temperature sensor (intake temp sensor). No effect. I really didn't want to consider the opti, but I'm pretty much out of ideas now. Is there a way to test the opti with it still on the car? Or am I spending my Sunday putting a new one on?? Damn GM.
Thanks
Old Oct 18, 2008 | 08:48 PM
Forgot....42psi fuel pressure...no drop. and put inline spark tester on a plug wire and it's firing like crazy. blue/white spark.
Old Oct 18, 2008 | 10:02 PM
jester1614's Avatar
if i remember correctly 16 and 42 are both opti codes
try cleaning both ends of the wire that runs from the opti to the passenger side of the manifold
opti is probably shot tho
Old Oct 18, 2008 | 10:37 PM
trump167's Avatar
did u check the (eng. sensor) fuse under the hood? i had a similar prob with an lt1 car throwing off da wall code and wouldnt run for anything and it ended up being a freakin fuse after changing every sensor on the car including the opti
Old Oct 19, 2008 | 07:03 AM
I looked in the fuse block under the hood and the one inside the car and nothing was blown.
Jester, are you talking about the wire harness that plugs into the opti?
Old Oct 19, 2008 | 06:48 PM
Ordered a distributor...should be here Tuesday.
Old Oct 24, 2008 | 03:34 PM
New opti in. Still dead. Changing spark plugs now.
Old Oct 27, 2008 | 08:24 PM
New plugs fixed the problem. When the opti died it fouled all the plugs.
Old Oct 27, 2008 | 08:32 PM
LT1's Avatar
LT1
Was there coolant leaking on the old opti?
